Overclockaholics Forums » Hardware Section » HDD's & Other Storage » Having trouble partitioning please help
Old 02-11-2011
ny_driver's Avatar
Default Having trouble partitioning please help
I'm using partition logic and I cannot seem to get 4 equal sized partitions. It partitions, but not the size I want after the 1st partition is created.
Trying to get this ironed out before next week when the SSD gets here.
Thanks for reading.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-11-2011
GeorgeStorm's Avatar
Why do all 4 have to be the same size?
What's going wrong?
I've never had issues partitioning drives after an initial partition?
Old 02-11-2011
i do mine in when installing the os
Old 02-11-2011
ny_driver's Avatar
I guess they don't have to, but would be nice if they were all fairly equal. I get the 1st one set to ~12GB and then when I set the 2nd one to the same amount of clusters it ends up being twice as big as I want. I want 3 for OS's and 1 waza.
I wish I could give better answers, maybe just try while installing windows.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-11-2011
should be able to slice and dice it any way you want in windows set up
diskpart works good for dos and if you already have XP on, use this...
http://download.cnet.com/Easeus-Part...-10863346.html
only 32bit is freeware so has to be used with XP for set up then your good to go
any of these should give you the desired result
good luck
Old 02-11-2011
NY do you have a screenie of what the partitions end up being?
Old 02-11-2011
ny_driver's Avatar
No I don't, but when I create them with the same amount of clusters each one seems to get progressively larger.
Never tried creating multiple partitions in setup before I guess that would be easy enough.
Thanks guys.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-11-2011
ny_driver's Avatar
Hey I got it figured out guys, I just did it in XP setup like you said.Thanks.
Now it's time to figure out spi before my triple channels get here
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-11-2011
Use Vista DVD to partition. It creates the correct offset for aligned partitions.
Important on HDDs it is even more important on SSDs
You can also use a non ultimate windows 7 DVD to create partitions too. If you use ultimate (or Pro I think) it will force you to add the 100/200MB partition for EFS, it is unneccesary and a pain to get rid of later so just use Vista.
Old 02-11-2011
ny_driver's Avatar
I didn't even get Vista yet, although I made a partition for it. I made the 4 x 14GB partitions with xp setup. Good size or too big?
And they are misalligned you say? I figured that would be the case, but it's ok this is just a test.
Should I just get Vista and install that 1st?....ohh and which version of Vista?
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
