Old 01-23-2011
Default Asus P8P67 WS
Just got this thing together.
Board: Asus P8P67 WS Revolution
BIOS: 1053
CPU Batch: LO40B705
S/N 35041346A1650
Not 100% done as I have some running around I have to do.
Just have one stick of RAM right now waiting on RMA set to show up
Quick auto tune results 4.533 Ghz at 70F room temp
The H70 is a POS but not as big a POS as I thought it would be ....
May be capable for it's it's intended use and decent to clock with outside
Old 01-23-2011
What's the temps like with the H70 idle and load? I was thinking of getting the H60 when it drops.
That's a huge case!
Old 01-23-2011
wow i love it...alu is shiny...i don't like black interiors
Old 01-23-2011
Intel CPU power saving BS still on
Idol: 22C (drops out to 1650 Mhz)
32M load & 4.533: 44C
will do a 1024 load in a few
Bigger case than I wnated buy it will have to do. mounting a handle on top and cutting a blowhole in the top eventually
the 580's throw some serious heat
Thanks Honda brand new case. I forgot what a PITA it is working inside one
Old 01-23-2011
My dilemma is I can install a lowrise CPU cooler, a Coolit ECO, Corsair H50 or H60 and that is about it. So thinking the H60 will prolly be my best bet.
I bet they put off some heat. Worried about that myself in my little arse case. Case allows for a GPU no bigger than 10.5" long and that is every bit of a GTX580! We'll see.
You plan on a different case or going to stick with this? What handle you have in mind?
Old 01-23-2011
Gotta say for a system that tight a one of these closed loop sytems may be the ticket as opossed to a pancake air cooler.
They are not great but preform on par with top of the line air
Gettin rid of the heat the 580 will make will be paramount. \
This case is 15" high and 19" deep, going to roll with it
Here are some I have been looking at
http://www.reidsupply.com/Results.aspx?pid=10022021
Old 01-23-2011
Have you seen these?
http://www.performance-pcs.com/catal...ducts_id=23828
Expensive as all hell but you can put them together as one.
My case is 14" high and 13" long!!!
Old 01-23-2011
Is it the Nzxt with the built in handle ?
I was looking at that when I was thinking micro ATX ???
They look nice ..... they are expensive little bastards for sure ........
Old 01-23-2011
You could have used one of these and mounted the rad external... http://www.newegg.com/Product/Produc...82E16811163112
Old 01-23-2011
LOL .......
I think it is the new Lian Li with the two fan front .
http://www.newegg.com/Product/Produc...82E16811112300
Here is the prime run
