Overclockaholics Forums » Hardware Section » RAM » Which Kit For Daily?
Old 12-23-2010
Cecil Cecil is offline
Cecil is just getting started
Default Which Kit For Daily?
Just put together an i5 gamer with a 650 and M3F. Had ordered a set of Patriot sector 5 2000 9-9-9s and they ended up being 9-11-9s that wouldnt run over 1500. My Corsair sticks do fine up to 1800, but they belong in my HTPC.
Im looking for the cheapest option to run 1800Mhz 8-8-8 or better daily, and have the possibilty of doing 2000Mhz with half decent timings. They got to match the look of the board though
Was looking at these,
http://www.newegg.com/Product/Produc...82E16820231412
http://www.newegg.com/Product/Produc...82E16820231410
http://www.newegg.com/Product/Produc...82E16820145291
http://www.newegg.com/Product/Produc...-123-_-Product
I assume the Gskills are the same. Mushkin Sean posted at mushkin forums saying the Ridgebacks would do 2000 7-10-8, but Ive never seen it anywhere. I guess they are the same as the Redlines but bigger heatspreaders. Im leaning towards those cause of the price.
New Sig To Come
Old 12-23-2010
7-10-8 is doable on air.....
7-10-7 if you raise the voltage a little
i don't mind doing the psc...they're actually ok.
but i still prefer kingston high speed rams. anyday...
Old 12-23-2010
Mushkin Enhanced Ridgeback
Old 12-23-2010
newegg sold out of the ridgebacks, but I found these on Amazon,
http://www.amazon.com/Mushkin-Enhanc...3158714&sr=8-2
New Sig To Come
Old 12-23-2010
like these ?
http://www.newegg.com/Product/Produc...82E16820231351
Old 12-23-2010
luvin these for $ 65 bucks AR
http://www.newegg.com/Product/Produc...82E16820226103
Old 12-24-2010
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
Thanks Brian. Just what the doctor ordered for my DD update.
Old 12-24-2010
I would rather have 1333 6-6-6 over 1800 8-8-8 anyday. But I am an AMD RAM guy mostly
I never noticed much of a differnce on any of them for speed. Once you have enough bandwidth more does not help, only latencies. it is usually easier to get tighter than it is faster IME to lower them.
Old 12-24-2010
you should try sp32m for comparison
Old 12-24-2010
Even with AMD higher speed helps if you NB speed is high enough. I think the NB bottlenecks your mem bandwith untill its double the speed of the ram or something like that. Its been a while, but that sounds right.
I did a comparison a while back, and there was much of a difference with the timings or speed untill I upped the NB to 2600 to ease up on the bottleneck. Fastest Spi32 I got was 1600Mhz 6-6-6-18 with NB at 2600.
New Sig To Come
