Old 12-20-2010
Default ATI + AB = WTH BBQ [Solved]
Can't seem to get MSI Afterburner to work for the ATI GPUs. Keep getting "Failed to initialize display driver wrapper" error. I've reflashed the OS and reinstalled drivers a couple of times before installing AB and am still getting the same error. Had no such trouble with the Nvidia GPUS, AB and Rivatuner worked just fine.
OS: TinyXP Rev9
MOBO: Tpower i45
CPU: e8500
GPU: 5870 & 4870
Display Drivers: Tried 10.3, 10.4, 10.11, 10.12
Chipset Drivers: 9.1.1.1020
MSI Afterburner Version: 2.0.0
WTF am I doing wrong?
__________________________________________________ _______________________________________
[Problem Solved]
Looks like I needed Microsoft .NET Framework 2.0 installed. Duhhhh.........
OCM
Old 12-20-2010
Try older AB and see if that helps? maybe 1.51 or older.
Old 12-20-2010
Oh did you image your OS's with nvidia cards/drivers installed? Just shooting from the hip here....
Old 12-20-2010
No, imaged without display drivers. Gonna try an older version of AB once I get home from work.
Thanks,
OCM
Old 12-20-2010
try installing the display driver...
Old 12-20-2010
If OCM is trying to run AB with no display drivers installed then he owes us a livestream in his undies.
Old 12-20-2010
LOL. Display Drivers are installed and reboot before installing AB. Home now, time to figure this thing out.
OCM
Old 12-20-2010
i dont wanna see that ... but idk about you after the other thing you said
Old 12-20-2010
OCM
Good deal. Make sure to let us know the fix in case one of us run into the same problem.
lmao My name isn't Splave so that kind of stuff isn't my cup of tea. I would be sure to link the feed up on hwbot for maximum humiliation.
Old 12-20-2010
Just ran through all AB versions to no avail. Also tried ATITool 0.26 and still no worky worky.
