Overclockaholics Forums » Welcome to Overclockaholics » General Discussion » I think I bricked my DFI LP UT Ultra-D
Old 12-08-2010
ny_driver's Avatar
Default I think I bricked my DFI LP UT Ultra-D
I think I must have reinstalled the chipset HS so that it shorted something out.......is the only thing that makes any sense to me. I took everything apart and let it sit overnight to no avail.
Any suggestions? .........currently hunting for another board that I cannot afford.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-08-2010
What are the symptoms? Does it even power on, does power on but only posts to a certain point or what?
Old 12-08-2010
ny_driver's Avatar
All I get is the standby LED. No POST at all...no beeps or anything.
EDIT: and I'm sure the chipset cooler is on there evenly now.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-08-2010
you can remove the motherboard heatsinks and just check if it can post...
Old 12-08-2010
ny_driver's Avatar
Just as dead with no HS on the chipset..........ohh well it's not as bad as bringing home a wrecked snowmobile.
The guy I got it from suggested baking it at 350 for 15 minutes.....isn't that what you do with a GPU?
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-08-2010
Have reset the CMOS as well as pulled the battery and let it sit for awhile without the battery in?
Old 12-08-2010
350F ...thats where some solder melts..lmao..he's an idiot.....when i say melt...components will fall off.
Common solder alloys are mixtures of tin and lead, respectively:
  • 63/37: melts at 183 °C (361 °F) (eutectic: the only mixture that melts at a point, instead of over a range)
  • 60/40: melts between 183–190 °C (361–374 °F)
  • 50/50: melts between 185–215 °C (365–419 °F)
Old 12-08-2010
ny_driver's Avatar
Yup I let it sit all night but you know what I haven't tried and am going to right now is another cpu. BRB.
And I didn't follow his advice....I figured I should ask first.
EDIT: not the cpu.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-08-2010
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
What do the 4 red LED's stop on?
Old 12-08-2010
So does that mean you wont get to bench that FX55? bummer.
Mr. Scott Has your team inherited the Pure logo for your bot sig? looool
