Overclockaholics Forums » Welcome to Overclockaholics » Member's Rigs » Chiller's Hybrid SR-2 in Level 11 mod
Old 11-18-2010
HybridChiller's Avatar
Default Chiller's Hybrid SR-2 in Level 11 mod
Hi guys, fellow OCers.
Here is show you my build i'm working on now that is for 24/7,
if this one is ready, the OC starts again after almost a year no overclocking.
Dropped from 570 to 372points ggrrr
I'm from belgium and i'm crazy about Extreem OC and making some custom stuff.
Hardware what will come in this rig is :
2x Xeon X5550
Evga SR-2 mobo
Evga SR-2 1200w psu
3x Evga GTX580 superclocked
Ocz RevodriveX2 240gb
Corsair Dominator GT 2000Mhz cl9 12Gb kit's
Level 10 case
and some crazy stuf....
This build is made possible by and thanks to
Evga Taiwan
Thermaltake Taiwan
Angelbird Austria
Aquatuning Germany
Xtreme Case Mods Australia
IT-Service Belgium
Cooler Master Benelux
Zetix Belgium
Here are some pics of my rig now :
And this is how the case is on this moment, also fitted a 16x2 red/black lcd above the Boreas chiller.
Also you see now how hidden the ATX24pin really is, pure cable management with the 90° connectors :
Total overview of the case how he's now.
Most of the cables are on/in it : audio, usb, powerswitch, hdd led, power led, reset, reset led, debug lcd, 2 sata, all atx and pci kabels.
Evga PSU is also on his place together with the dual bay psu in front :
overview of mobo with all cables on it :
Also i have made a cable for the EVbot connection in the mobo IO-Shield, so the connection will be in the front plate, where it's easier to acces to hook up the EVbot :
Total overview of the current cables in the case lols,
but they are not all the cables yet, and need also some controllers to put there
(coolit, koolance, poweruse) :
Old 11-18-2010
Just realized this is one of the rigs entered over at the Coolit contest lol. Had this have been finished you most certainly would have won it hands down. Very nice detail and outlandish performance will certainly ensue! Can't wait to see the performance data on this...keep us posted!
Btw, do you intend to cool both cpu's with the Boreas and are you using the stock pump?
Old 11-18-2010
the boreas is not the only one that's in there.
there also comes a Freezone Elite and a Freezone V1 in this case.
I will make a pic with all coolers in there.
Pumps will be the stock pumps, if they are not good i swap them for Koolance pmp400 with heatsink kit on.
Normally i whanted to have 3 coolit pumps in there, i will be happy if i get 2 pumps in it lol.
Old 11-18-2010
I have two Boreas atm...one for bench work that still uses the stock pump and the other being used for the 24/7/Gamer which uses this pump...http://www.performance-pcs.com/catal...ducts_id=25392
They both do about the same as far as I can tell except the stock pump is slightly noisier.
Old 11-18-2010
what cools better? the stock pump or aftermarket pump on the coolit coolers ?
Here are some pics with all coolers on there place, now you see also why i make the 90° connectors on the mobo :
Here you see, with fittings and all, i calculated just enough space for cpu block etc :
and this is why i made those 90° connectors, so maximum on cable management :
And here is my youtube channel, so you can see the case in 3d :
http://www.youtube.com/user/BabySkylineS14
Old 11-18-2010
No difference in temps between either pump and aftermarket waterblocks have little effect as well...those stock blocks are double fugly tho arent they?
Don't let MD see this...he will surely have to have one!
Old 11-18-2010
who's MD ?
I noticed temp difference with an HT3.0 and koolance 360 block against the stock vcoolit block.
but pumps i don't know, that's what i whanted to know.
i have 4 coolit pumps.....
Old 11-18-2010
Chiller and your crazy awesome build
Old 11-18-2010
thanks, it's also a nice forum hihihi
Old 11-18-2010
spfoam1's Avatar
spfoam1 spfoam1 is offline
Lurker
That's a serious looking machine.
Welcome to the forum.
