Overclockaholics Forums » Hardware Section » Cases » CC Benchtable v2 "White Shark"
Old 10-24-2010
crio's Avatar
crio crio is offline
Default CC Benchtable v2 "White Shark"
The time has come for me and my friend Jason to present our first benchtable.This one is made for Boton and i hope it is the first one of many many more to come...
Now its time for pics
Crio OC
Old 10-24-2010
wow i love it...finally a table for the holics
video please
Old 10-24-2010
Nice! How much them going out the door for?
Old 10-24-2010
Looks real Good Crio.
If I might make a couple suggestions...
a) Make the PSU area larger as not all PSU are going to fit in the that configuration and you also do not want to impede air flow through them.
b) A PCI Expansion bar would be a good idea especially for the GPU LN2ers
A couple of long threaded rods mounted either just by the PCI area, or on either end of hte motherboard with a piece of strap steel hanging between them. If you run it the whol length of hte mobo... you will need to use thicker metal... but you can always use a third rod in the middle for strength.
c) Doing the expansion support bar the whole length of the board also would allow you to make fan mounts around the CPU socket area for FET cooling instead of just hanging them off the POT.
d) wing nuts to hold the top to the bottom for faster access to the HDDs. (Or use a "tool less" HDD mounting design )
Old 10-24-2010
awesome I like the sparks picture
Old 10-24-2010
crio's Avatar
Thanks guys.
P.S. 1 : Neuromancer i am already thinking about the improvements...
P.S. 2 : For OCAs a speacial price will be made if asked...
Crio OC
Old 10-24-2010
Uh, yeah, thats pretty awesome dude. Nice work!
OCM
Old 10-25-2010
Here is what I would add to it.
Old 10-25-2010
crio's Avatar
Can be easily done
Crio OC
Old 10-26-2010
crio's Avatar
Time to show you another one.....
CC Benchtable V2 "Blue Velvet"
This one is made for Tsan and has no HDD bay cause he wants two PSUs under the hood.So modded to fit two PSUs....:p
And some piX with its brother.
Crio OC
