Overclockaholics Forums » Hardware Section » PSUs » 850w enough juice?
PSUs Lets Talk Power...
Old 10-02-2010
Default 850w enough juice?
Looking at getting a new PSU for my benching rig. Currently running a Corsair HX620w and its time to go bigger. I do understand that the psu isn't a place to skimp but I am on a shoe string budget at the moment.
So, will this Corsair AX850 handle the load of some Dice/LN2 action and a couple of GPUs in Crossfire/SLI without skipping a beat?
http://www.newegg.com/Product/Produc...9015&Tpk=ax850
Or hould I step it up to this 1000w?
http://www.newegg.com/Product/Produc...007&Tpk=hx1000
Or should I just save up for an overkill 1200w-1500W PSU?
Or, bear with me, should I run dual PSU's. 850w for Mobo/GPU's and 620w for all other aux stuff like, fans, pumps, hdds, ect...........
My brain is like a pretzel right now
Thanks,
OCM
Old 10-02-2010
The 1000w Corsair you have linked is modular.
Old 10-02-2010
Nice catch, I ment fully modular. *Edited*
Old 10-02-2010
hx1000 is not good imo
as for 850w.....best is the hx850....
ax850 is ok..but the hx850 is better for oc...
Old 10-02-2010
Dual psu's are also cool if you're running a water setup. take the un-needed strain off your main rig. I never use my main psu for any water cooling pumps,fans, etc. and i have a 1200w Pc power&cooling main psu.
Old 10-02-2010
Ok, so does the HX850W have enough juice for benching stable on Dice/LN2 with a couple of of GPU's in the loop? And just keep the HX620W for all other duties.
Old 10-02-2010
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
Negative. The AX is the superior PSU. The two are actually almost identical except the AX has a higher efficiency rating and generates less heat overall. Slightly less line ripple on the AX also.
Old 10-02-2010
So will a quality 850w PSU have enough juice to bench stable on DICE/LN2?
Old 10-02-2010
Depends on the setup.
Mobo:?
CPU:?
GPU:?
HDD:?
Old 10-02-2010
AM3 Mobo
1090T/965BE
2x 5770's
For starters
The HX620W can take the duties of everything else. Pump, Fans, HDD, ect......
I guess a better question would be, what can I expect a quality 850w psu to handle?
