Old 09-06-2010
underdog1425's Avatar
underdog1425 underdog1425 is offline
underdog1425 is just getting started
Default Benching Chiller
Hi all
This is my benching run chiller, nicknamed by my LAN mates the Deathchiller. This is it's 2.1 revision.
I am running ~8ft 0.9mm captube (kind of tongue in cheek measurement on length I know..im bad)
The exchanger and the captube are the current modifications that I made to the 2.0 revision, and there is more work to be done. (like cleaning it xD)
Among other things, I need to acquire a new pump as mine busted. Who knew the D5 was so fragile?
On to the chiller.
New exchanger. Basically instead of the evap inside of the water loop, now the water loop is inside of the exchanger. Inb4 cascade =] (thats pretty much where the idea came from)
The brass is the inlet, the copper is the outlet. I still need to flare the copper outlet as it is 3/8" and my 7/16" tubing is huge on it..(there is a joke in there somewhere O_o)
Cap tube dumps near the 180 bend, suction pics up at the other end. While I did want to run the evap through the full 180 bend, I just didn't have the material to do it with and I am trying to do this with as little investment as possible and still do things "right" as I am currently between jobs (start work on the 13th thankfully though).
Hopefully this design will eliminate some of the issues I was having previously and yield better efficiency.
The cap tube definitely makes a difference. Its also interesting, as soon as things start icing over, it completely ices over FAST. This is something I didn't see on the shorter cap tube.
about 7 minutes in..
maybe 1 minute later, possibly 2..
I have not water tested it yet due to dead pump. Considering cannibalizing my water setup for it's D4 pump and just cruising on air for the time being..dunno yet.
Stay tuned!
Overclocking and freezing-things noob.
http://lanifesto.org/ The only hardcore BYOC LAN in Alabama.
Old 09-07-2010
to the forum Underdog. Nice lil project you got going, tuned in for the updates.
Old 09-07-2010
Wow .... not sure how this works
In for the results
Old 09-07-2010
awesome! you killed that pump bad man. Looks great
Old 09-07-2010
In for the results
LOL I am a little confused as well.
Crazy setup
Old 09-07-2010
Thanks for the welcomes guys.
Crazy setup
This exchanger I kept ranting about will chill 100 proof vodka for a cpu only loop. Basically using it instead of a radiator.
Dunno if this is condescending, but here is a diagram for people who are new to this (like I was..and still am =])
Old 09-15-2010
No news is good news I guess. Started working again this week at starbucks xD
Also physics test this coming tuesday so there probably won't be much work done over the weekend.
Trying to sell some stuff over on OCN to build up funds for another pump.
Any chiller veterans have recommendations for a good but inexpensive pump other than MCP655? If not I will just get another one of them (used hopefully, college budget is baring its teeth at me).
Old 09-15-2010
Man how did I miss this thread? Nice setup man. Good luck on the fund raising! I had to get a 2nd job to support my needs. Back to working 64 hours a week again.
Old 09-15-2010
super nice setup bro! GL getting it up and running..
make sure keep on posting!
Old 09-16-2010
Geez 64 hrs and you find time for play in there?
Thanks for the compliments guys, will keep updates as I can.
