Old 09-06-2010
Default Manual Wazza Video
Basic idea on how to run it.
You can play around with
-page file size
-max mem size
-wazza file sizes
Good luck guys, feedback is welcome. Was easy to make I can always remake it.
Old 09-06-2010
Thanks Splavestick! Im at work so I can't check it out but I sure watch it when I get home.
Old 09-06-2010
Are you a frigging mute or something?
Old 09-06-2010
Splave, the bb code for embedding the youtube videos is [yewtube] (<----correctly spell youtube] [/yewtube]
So you take everything aftger the "=" in the youtube link "Z2VdSWktL_g" and place it between the youtube tags:
[yewtube]Z2VdSWktL_g[/yewtube] and it will show your video embedded on the forum.
The resolution used for the video is a bit too tinsy tiny and I'd love to hear your San Fran man voice giving a narrative
Old 09-06-2010
Very nice...
Gotta say even with that recorder app running your inital and first loop times are the same as mine was LOL
DAMMMMN
Thanks for the idiots guide to wazza splave
Old 09-06-2010
I bet Splave sounds like Mike Tyson...
Old 09-06-2010
No you wrong! He is a very manly man!
Old 09-06-2010
rofl, yeah you have to go to the youtube link pick 480p or 720p then full screen it to see. Its hard because you need the higher resolution to show it so best to go to the link to see it in full screen
Old 09-06-2010
lol no just didnt feel like setting up a audio recorder on my bench OS
+ now you can pause it and read it if I go too fast
Old 09-06-2010
In office cant see, if I may ask what gives you the best result? do you guyz only do CW or CDT as well???
