Overclockaholics Forums » Hardware Section » HDD's & Other Storage » SSD Tweaking Utility - worth a try
Old 08-29-2010
Default SSD Tweaking Utility - worth a try
http://www.ocztechnologyforum.com/fo...-Tweak-Utility
enjoy
Lets you Tweak the following:
  • Windows Indexing Service
  • System Restore
  • Windows Defrag
  • Use Large System Cache
  • Ntfs Memory Usage
  • Disable 8.3 Filenames
  • Disable Date Stamping
  • Disable Boot Tracing
  • Windows Prefetcher
  • Windows Vista Superfetch
  • Windows Services
Old 08-30-2010
Thats a pretty old utility and don't think its needed anymore.
The only thing I turn off is defrag.
Things like turning off system restore will mess you up if you ever need to do a driver roll back. Turning off date time stamps will also mess up your backup software when you only backup recently changed files.
That software was used for the first OCZ drives that had issues and not needed anymore. I basicly use my SSD's just like a HD and do nothing different for them.
Old 08-30-2010
What SSD's are you running now Bill? Still on those Mtron's?
Old 08-30-2010
Yup
Old 08-30-2010
karmakazi's Avatar
All those options can be changed with a simple .reg file. No need for extra software
Old 08-30-2010
im just sharing the file. heheheh
which .reg file is that? or you mean regedit?
Old 08-30-2010
you can create a .reg file with the right settings, and simply run it to change settings in registry...
Old 08-30-2010
ahhh so we need to make a reg file... for oca
Old 11-05-2010
v1.6.1 is out
http://www.techspot.com/downloads/4926-ssd-tweaker.html
