Old 08-23-2010
Default Different Type of Overclocking Leagues
http://hwbot.org/forum/showthread.php?t=9801
Originally Posted by assman
Hey boys and girls,
Given the recent commotion about the Overclockers League being totally unfair (), we have tried to come up with a different style of overclocking league. As a try-out, we've made a very rough sketch of what could be an AMD overclockers leauge. The link is not visible through the front-page (since it's not an official feature), but you can check out what it's all about here: http://hwbot.org/rankings/amdleague/
As you can see, without too much issues we can make rankings based on specific hardware or manufacturers. This page is a nice concept of one of the ideas we've been playing with to seperate the extreme overclockers from the regular overclockers. Instead of thing top-down (eg: pro league), we've made an alternative going bottom-up. This means that we do not seperate the super-seeded from the regular-seeded, but the extreme from the non extreme.
The enthusiast league:
- cooling limited to ambient (= stock, air, water)
- frequency of each CPU and VGA limited to undisclosed value to prevent cheating and golden samples ruining the game
- no seperate result ranking based on cooling, points are gathered from the normal rankings(*)
- possibly: exclude expensive hardware from rankings
The extreme league:
- no cooling limitation
- no frequency limitation
- points are gathered from normal rankings (*)
(*) the normal rankings are rankings based on the hardware/manufacturer limitation. So, for this AMD league, the points are not calculate based on the entire database, but only based on the results with AMD/ATI hardware. This means it's possible that certain benchmarks (eg: 01 and 1M) have less weight than the normal rankings because they are a lot less popular than when you include intel hardware.
The idea behind using the same rankings for the enthusiast and extreme rankings is that there will be noticable transition when you switch from ambient cooling to extreme cooling. To show you how it works, this example:
- my best score on ambient cooling is rankined 89th in the superpi 1M ranking; I get 20 points for that.
- those 20 points are added to my total for the enthusiast ranking; I now have 180 points
- the next day, I use LN2 to cool my cpu and get a score that is ranked 15th in the 1M ranking; i get 60 points for that.
- these 60 points are added to my total for the extreme league
Since only your best submission is ranked, the submission with ambient cooling now receives 0 points. So, the total for my enthusiast league has dropped with 20 points. This method applies to all rankings and categories, which makes it a necessity to only choose for ambient, or only choose for extreme overclocking (since you cannot have two accounts in hwbot). So, you can be the Extreme King, or the Enthusiast King ... but not both. This, to make sure the extreme overclockers play in their own league.
Note: the current ranking has not been calculated as explained above. It would take too much time to do it properly, and time is something we do not have available currently. At this moment, we just make a sum of all points that are added to AMD/ATI scores.
Old 08-23-2010
Right, right. I like.
Old 08-23-2010
hmmm..... what about when the cpu is extreme cooled, but the gpu is stock or water cooled? where does that go?
Old 08-23-2010
Total fail in my book. I expected nothing less from hwbot crew though. They know best and all they have to do is "educate" us on how things should be done. Kinda like Obama if you think about it.
I just find the "undisclosed" frequency limitation and whatnot after all of their excuses for not doing something before. This actually contradicts their own words.
Old 08-23-2010
I am 87 out of 100. *sigh
Interesting idea, can't say that I hate it. But if it is truly separate than it would only hurt the top clockers yes?
The enthusiast league sounds interesting I am sure it would not be too long before people figure out the limits though. 99 submission for every processor at 4.299 GHz
blech. whatever happens happens.
Old 08-23-2010
i think this is more for air and water coolers....
air and water guys are surely numerous...hwbout would love to have them onboard.
Old 08-23-2010
why do they always need to change everything?
no way to make sure of type of cooler. Also so now an overclocking website is limiting your overclock. Something is very wrong here.
Just get rid of ES bullshit scores and be done with it.
Old 08-23-2010
Allen I think you are missing the point. I see the cons... but I dont think they are what you think they are. The benefits are that... everyone gets to compete at some level...top "air cooler" or what have you... and yeah who makes the top clock? Anywho...
The other Pro is... you get to submit your testing phases and get more boints from it.
(unless you run LN2 24/7 then well I guess you are fucked)
The con is... this is not going to help the guy that cant afford LN2. Because the guys that can still OC on air/water to practice submit.
I did not see anything about the leagues being mutually exclusive. That LN2 guys couldnt hit up the AIR league or AMD league wahtever it was (not sure.. I do "okay" on air or AMD... without LN2... better than the average joes at least. I only got as many points as I do (which is not much) because of DIce/LN2 and Intel+GPU benches. Cant think of one 3D benchmark that is not intel specific.
For that matter. How about throwing in some actual GPU benchmarks. not just "futuremark system benches" Why does a 3D test need 2 out of 4 benches to be CPU?
They are trying to fix what is wrong with the bot. The problem is... the have no clue. How about GPU tests that test the GPU, not the CPU.
or have 2D 3D and system (IE futuremark) tests...just a thought.
EDIT: Just thought of something else....
HWbot used to be on the number of submissions per device... so SLI got easy points. Might this be the case in v4... and removed in v5??? Probably. Except this time it would apply to CPUs....
Old 08-24-2010
Oh they forgot all about actually scanning submissions to make sure they are legit, not copies, or shared scores.
Yup FM can do that right now if they wanted to. Shoot they don't even check keys. The Bot has nothing.
How are they going to handle all the different tricks people play with Water Cooling/Air Setups. AC blowing on your Air Cooler, Chilled Water Loops etc.
Its all good and I think people need there seperate play gounds so others can play, but lets fix the basic stuff first.
Yes on remove ES chips removal.
Leagues should also consider sponsored guys, seperate League for them. Do this so we don't get the dirt track guys being forced to play in the Indy Car League.
Old 08-24-2010
Don't really care anymore.
Whatever they decide, I'll adapt.
Whatever system/level you talk about, it's 20% tweaking and 80% binning anyway. With NDA mods and ES wild cards thrown in.
