Overclockaholics Forums » Overclocking Section » Volt Mod's » PUNX can you take pics of your 460s?
Old 08-07-2010
Default PUNX can you take pics of your 460s?
we need to figure out the vmod for the compo
Old 08-07-2010
are they all the same pcb ? whats the mem size also ?
Old 08-07-2010
1gb I believe they are all reference this early in the game
Old 08-07-2010
Talking got them off of TPU
Old 08-07-2010
I thought nV released these to have non-reference pcb's right off the bat. There are already pretty hefty stock-clocked versions available. Bet those are cherry cores?
Old 08-07-2010
Quick google shows refernce boards.
Also shows no voltage control on anything but ASUS 460s.... oooooo
Hope EVGA comes out with one, as I want to give the 460 a turn n burn....
Old 08-07-2010
which comp is this?
Old 08-07-2010
which comp is this?
I imagine the QuakeCon 2010?
Old 08-07-2010
do you know what cards you will be using??? can you get me a copy of the stock bios?
I can mod it for more voltage.... check out my hwbot sub, taht was soft modded bios
Old 08-08-2010
we will be using 1gb 460s
hell I will slap an evga bios on there if we have to!
