Overclockaholics Forums » Hardware Section » GPUs » ATI » 5970x2 cross fire x fan control?
Old 07-20-2010
Question 5970x2 cross fire x fan control?
Anybody aware of the fix to get the second card fan speeds to respond?
I finally got my new 24/7 system up and running but theres a hitch on gpu2's fan speed.
System Specs:
Intel 980x
ASUS RE3
2x3 Perfect Storms
5970 x 2
Asus Xonar X2
4xRaptor on Areca 1220 Raid 0
HDDVD/BluRayray
Silverstone 1200w Zeus
Romulan Accessorized Bancheto 101
Old 07-20-2010
sick 24/7 sys!!!
sorry no answr to your q.
sick!!!
Old 07-20-2010
Does it work by itself? Do the cards have the same bios? Which drivers have you tried? Why are they called horse shoes? Are there any horse socks?
Old 07-20-2010
Its wierd, set both GPU fans to 100% and GPU1 will scale up in fan speeds in the os while GPU2 sits like a bump on the log. At shutdown, GPU2 jumps to 100% just before shutoff.
Drivers: Latest from ATI. 10-6
Tried CCC alone and then tried Afterburner latest vanilla edition to no avail. Feeling like dumping GPU2 right about now.
Update, opened GPU-z to find out bios revision and GPU2 fan speeds increased. Uknown if it'll stay that way in 3D applications?????
Old 07-20-2010
Dam supes ... That is a sick grinder you have there ...
freakin more hard core than my bencher ...............
Might as well say effit and grab some SSD ... don't want those mechanicals slowing you down
Quad Fire Driver support is a joke
I would dump one of them if it were me ...
If not :
10.3 will be your best shot IMO if you stay with two
If not what about the OEM crapware control software that came with them ?
what's the flavor
Old 07-20-2010
I like the way Witchie is going with this.... try installing precision or abe and link the cards, then adjust fan speed to see what happens. Worth a shot.
If that doesn't work, riva or ati tray tools should be able to lock the cards in 3d performance mode... that may do the trick as well...
Old 07-20-2010
Why do you need two 5970's to play UT3?
Old 07-20-2010
MSI cards, I'll try going backwards on the drivers but I seem to recall the same shit happening there as well. Hoped having these on the shelf long enough would enable some x-fire game testing. Seems manufacturers forget how to build things that just work!
Old 07-20-2010
I wanna see what I been missing by using the old 8800ultrasli action
Old 07-20-2010
Seat of the pants feeling is the Raptors are snappier than 2 intel ssd's in raid 0
