Old 07-17-2010
Question DDR3 and P55's
I have the Gskill Trident 2000mhz 3x2GHz kit and having some issues with getting up to rated speeds on my P55 setup. Everything works great on my X58, I heard the IMC on the P55's aren't as strong. So I'm wondering where the best place for voltages are without killing my hardware?
Old 07-17-2010
how high have you gotten so far? (both on mhz and volts)
And welcome to the forum!
Old 07-17-2010
Thanks you Face, so far I can only boot in with the memory running at 1333mhz in bios. I try for 1600mhz with no boot, I use 1.675 Vdimm 1.35 VTT. Not sure if I should be tweaking other volts as well or upping what I have
Old 07-17-2010
what is your p55 mobo?
Old 07-17-2010
Msi p55 gd-65 using the i5 655k
Old 07-17-2010
I think it's also heavily mobo dependent on this platform. I'm having a much easier time with memory on this foxconn Katana Inferno than I did with my P55 Classy.
If you haven't already, try backing off on voltage to 1.65 and 1.25. Sometimes there's an overvolt threshold a mobo doesn't like cold booting with, but will tolerate with incremental increases.
Old 07-17-2010
ram subtimings?
Old 07-17-2010
Nebber clocked that board but pch voltage always did the trick on the classy.
Old 07-18-2010
I've tried running them at 7-7-7-22-70 and back at to stock 9-9-9-24-74.
What PCH voltage should I try atm it's 1.08v.
Guess I'll have to find the mobo sweet spot.
Old 07-18-2010
can you take a pic of bios ram subsettings? anything memory...
