Old 07-09-2010
Default Coming Home
My SS is now in the hands of FedEx and on it's way home
Old 07-09-2010
good luck my friend
Old 07-09-2010
Chicken Patty's Avatar
enjoy it
Total Threads = 12
Old 07-09-2010
Good luck man. SS makes the life of a busy bencher soooo much easier
Old 07-09-2010
Chuch, now that you say that, and I don't mean to hijack this thread. Would you recommend for try SS first or DICE. I have never done any form of extreme cooling, just looking for the most straightforward method to get the feel of it.
Total Threads = 12
Old 07-09-2010
SS is nice because you bench on your own time. The problem is once you use colder methods its not that thrilling, but still fun. Convenience factor is what its all about. Oh an pre-testing. If you want the most possible excitement go with dice or ln2
Old 07-09-2010
wut happend to the ss ?
cp if you want the most i would go ln2 or dont wanna be buying ln2 i would get a casscde
i wish i had a cas cuz ss can only take u so far and i dont have alot of time to do ln2 right now even though i want to bad :(
Old 07-09-2010
This is all truth. I went from SS to DICE and DICE was so much more fun....but less convenient and if I had an SS I would have pounded out maybe not as fast benches, but more and across more platforms.
LN2>Cascade>DICE>SS
Old 07-09-2010
yeah im looking for something convenient. I know with cascades and stuff you just swap from one setup to the other and that's it, right? I meanj its just like putting a waterblock per say, you just use the proper mounting hardware and that's it?
Total Threads = 12
Old 07-09-2010
dice is almost like ln2..... (no need for dewar nor flask).. some welding gloves help. needs ventilation ...can't control temps......what you need. pot + acetone + dice
recipe:
1. good pot...incase you jump to ln2 world ..sf3d pot is 265, kp pot 2xx , d8r pot 2xx
2. acetone ..under 10$
3. eraser...under 10$ @ michaels
4. welding gloves...home depot...the dark brown is best.
5. dice and ice box ( styro hold better) grocery...
if you start with dice..you can upgrade later to ln2...just get a dewar and flasks...
i started with dice....its too addictive
i hope i didn't scare yah
