Overclockaholics Forums » Software Section » Windows 7 » product key question
Windows 7 The Latest & Maybe The Greatest...
Old 06-27-2010
spfoam1's Avatar
spfoam1 spfoam1 is offline
Lurker
Default product key question
I have several W7s laying around, and have installed it on several PCs. In the process of moving I have mixed up the PCs and the W7 DVDs, so I don't know which PC has which W7 on it. I don't normally peel the product key sticker and put in in the case because I swap stuff around too much.
Is there a way to determine which W7 is on which PC (all the same version so it's not like one is Ultimate and one is Professional and one is Home).
I just know one of you gurus will have the answer.
Thanks in advance.
Old 06-27-2010
I don't think it matters does it?
Old 06-27-2010
spfoam1's Avatar
Lurker
It matters because I will be giving away another PC or two soon, and I need to send the correct W7 DVD with each PC.
I could reinstall all of them, but it's a time consuming pain in the ass.
Old 06-27-2010
here ya go!
http://pcsupport.about.com/od/produc...bkeyfinder.htm
Old 06-27-2010
spfoam1's Avatar
Lurker
Thanks Splave!
..........and it works !
Old 07-02-2010
i was just about to say The Magical Jelly Beans!
Old 07-03-2010
It really doesn't matter. Just to be on the safe side, you can just change the product key to match the disk's sticker instead of running those programs, which don't always give the correct key.
Start => Rt. click "computer" => properties.
Scroll to the bottom, click "change product key"
make sure you are connected to the internet.
