Old 06-25-2010
Default How thermal paste spreads.
I saw this on another forum and ripped it off. It's a pretty good demonstration.
Old 06-25-2010
Jor-El's Avatar
Jor-El Jor-El is offline
Pretty nice Duke, what method you use guys?
The 'Spread Method' he showed is a bit flawed because he slightly pull the glass up letting the air in.
I use the spread after pre-heating the paste on top of the cpu IHS (+50c), then spreading w/ a credit card, then pre-heat the pot and install... The stuff 'melts' and gets very easy to glue/spread evenly pushing excess way.
//RETIRED OVERCLOCKER//
Old 06-25-2010
Good illustration there, nice post
Old 06-25-2010
I saw in some you tube type demo, that I think was for AMD, where they laid the TIM in lines that criss crossed the cpu like a star. One line vertically in the middle, one line centered horizontally, and then one line for each end to opposite end.
Found it works pretty well since a couple of 90 degree turns of the pot will give you a very nice coating of the entire cpu and pot, just don't get carried away on the amount of tim you put into each line rofl.
Then I run w/o and LN2 until I reach about 60C and shut down. A few minutes later I'll start pouring small amounts of LN2 as I restart the computer.
Seems to work for me
Old 06-25-2010
I just the dot method ... no time to dick around ...
I use a bigger dot ............ LOL
Old 06-25-2010
I've seen that video.
All that wiggling back and forth screws up an eraser seal and can incorporate eraser into your TIM.
I started using a star with i7, and especially with gulftown. A dot is fine for GPU's and 775's.
Old 06-26-2010
Old 06-26-2010
I use the Dot and a small wiggle. I always have.
Old 06-26-2010
I pay as I go...hate using credit cards for cpu's.
Old 06-26-2010
^ 757 Credit rating ............
