Old 06-10-2010
Default 830 Classified
Since I'm finally going off to college (postponing it for 3 years now). I decided to break down my bench rig and throw it in my Stacker 830.
Components:
Classified 760 (3 way)
3gb PI blacks
250gb HDD
285 Classified
1k ToughPower
WC:
HK 3.0
Mo-Ra
2x DDC
EK Dual Top
1/2" Tubing
Case:
Stacker 831
Sponsors:
Friend - EVGA 760 Hydro Copper Block
What needs to happen
1. Cut holes for CM
2. Sand the case down
3. Throw some primer on it
4. Sand some more and primer
5. Paint the case black and white
6. Rivet the case back up
7. Install hardware
8. Layout watercooling loop
9. Sleeve everything black + white + red
10. Plug everything in and take pics
This is the case but mine is all black even on the inside
Case De-Riveted
6/1
1st coat of primer on the tray
6/2
Rad + 760
6/3
Fitting mobo to tray
2 coats of flat black on the tray, i still need to paint the white ( its just primer).
bought some paint
6/6
Tray is almost done, just need to clear coat
Just for fun pics
6/10
Old 06-10-2010
She's a beaute bro, gonna serve all your knowledgable needs to make your head swell with an edumacation
Old 06-10-2010
looks awesome bro... cant wait to see her runnin
Old 06-10-2010
Thanks guys
I hope i can finish the case by sunday, i need to pull out the jigsaw and fix a cut i made with the dremel. After that i can paint the last 2 panels and rivet those in.
Old 06-11-2010
looks real nice assassin, very clean.
Old 06-11-2010
Looks real good buddy. Makes me miss playing inside the box
Old 06-11-2010
schweet! where does the 762 fit?
Old 06-11-2010
RomDominance's Avatar
Looks great A! Nice work bro and best of luck in school!
Old 06-13-2010
I'm almost done with the case, i tried working on it over the weekend but i ran out of paint. I was about to go to Home Depot when my truck didn't start :( , battery was dead. Have to go to sears tomorrow to pick up a battery and buy some paint.
I'm glad it happened at home and not when im in sac.
Also i need to pick up some toys thanks to an AWESOME FRIEND ! (you know who you are!) i have a 930 + 760 mb block which will be installed tomorrow.
Im hoping i can finish the case by weds and i can get started on wc placement
Old 06-14-2010
little update
