Graphics / Other For all You Other Software's....
Old 06-07-2010
Default Get your Sled on!
http://www.nvidia.com/object/cool_st...ml#/demos/2117
It's the Supersonic Sled demo from nvidia.
Thanks to Assassin for pointing it out to me.
Old 06-07-2010
dude weve been destroying this demo/game in the lab for awhile....
(a lil hint.... use teh chicken gun to break stuff off the sled to go faster)
if you want i have more hints
Old 06-07-2010
Default Supersonic Sled 400 series only
Strap yourself in and get ready to experience the future of gaming realism and interactivity that only the GeForce GTX 400 Series of GPUs can provide. Taking advantage of PhysX, CUDA, DirectX 11, and 3D Vision, Supersonic Sled straps you on a high powered test rocket and hurtles you down a six mile long track in the Nevada desert at speeds in excess of 800 miles an hour. You’ll have to avoid falling rocks, destroy buildings and bridges, and avoid flying off the side of a massive cliff.
Every moving object in the demo is physically simulated using PhysX and CUDA. From the falling rock debris you have to traverse, to the dynamic smoke that swirls around the launch pad when you take off, to the thousands of individual pieces the house and bridge you’ll fly by break into – every interaction between moving objects in Supersonic Sled is simulated on the GeForce GTX 400 Series GPU – helping create one of the most physically realistic and accurately portrayed real-time technology demos ever built. Be sure to turn on Visualize Physics mode to see all the PhysX forces in the demo. And if you really want to have some fun, try breaking the sled apart by throwing chickens at it – or placing crates on the track in front of the sled before it takes off. The best part is that no one run will be exactly the same. Every time you blast down the track in your rocket powered sled, you’ll have a truly unique and dynamic experience.
Download
Old 06-07-2010
My high score is 21.73
Old 06-07-2010
lol
My bad, i made a thread over in the gpu section. I didnt see you made one.
My high score is 21.73 secs
Old 06-07-2010
my best in around 16 seconds... i will get a SS later of it.
Old 06-07-2010
It doesn't count till you have a SS
Old 06-08-2010
NP homie...
Old 06-08-2010
new record with a stock sled nothing removed
19.1 secs
Old 06-08-2010
New Record !
18.8
