Overclockaholics Forums » Overclocking Section » Overclocking » i5-650 or i5-655K for water?
Overclocking Air & Water...
Old 06-03-2010
Cecil Cecil is offline
Cecil is just getting started
Default i5-650 or i5-655K for water?
Is the unlocked multi going to help with my water setup, or be waisted? Just going to bench it for some global points, then probably sell it with the GD-80.
And assuming I can get 4.9-5 benchable with water, is that enough for some global in Spi and Pifast, or just wprime?
New Sig To Come
Old 06-03-2010
5ghz is doable with 32nm.....
32nm is low power versus 45nm....
lower heat..but still 32nm stability requires lower temps ....
Old 06-03-2010
Get the 655k. Once you have played with the unlocked multi you don't want anything else. IMHO, the unlocked multi lets you really maxmize the whole system by finding the sweetspot for memory and everything. Then just find the multi that works for that bclock.
Old 06-03-2010
this! QPI is crucial to these chips performing. Memory as well instead of raw mhz power. Ive had great luck with the 655k 5.0ghz under 1.5ghz valid your points will come in wprime and spi1m on water Price is excellent too.
Old 06-03-2010
Well, just got hit with way too high of a phone bill, so this is on hold for now. Maybe next pay :(
New Sig To Come
Old 06-03-2010
Yah but you gotta admit the unlocked multi makes life alot better. Is high bclock required for crazy high QPI?
Suckos, I'm playing the low budget game right now too.
Old 06-03-2010
nope so many different QPI settings doesnt really matter. Great chips! I may have to pick a couple retails up
Old 06-03-2010
Your results (and the price) made me just pick one up instead of trying another 670.
Sheesh. $220 to play with an unlocked multi? It'd be weird if they didn't sell like hotcakes to mainstream overclockers.
Old 06-03-2010
The 875K for $300 at MC is tempting for a 24/7 use CPU, if I had the money lol
New Sig To Come
Old 06-04-2010
I hate all 8** chips lol!
