Old 06-01-2010
Archer's Avatar
Archer Archer is offline
Archer is just getting started
Default Temp Meter
Thinking about dropping a blog/review on overclockers.com and was wondering if anyone had any suggestions for other testing that can be done other than cooking?
The 72-7712 Digital Thermometer from Tenma Test Equipment is a dual thermocouple meter with internal logging capability, USB output for saving logged data and software up-link. This unit can become an integral part of a PC testing arsenal by allowing for isolation of case hot spots, heat sink testing and LN2/Dry Ice work. The limitations start to change and the performance bar can be raised when you know where it is hot and where it is not.
Here is a link to the review @ techreaction: http://www.techreaction.net/2010/06/...s-inside-a-pc/ I want to use some of this content but also want to change some tests. Ideas please.
I generally play with nothing but air.
Thanks
[CENTER]I am my AVATAR and YES WE have an ATTITUDE problem
905e @ 3600 1.35v | Biostar TA790GX 128M | 8 GB G.SKILL 800 ram @ 888 4-4-4-12 2T | 9800 GT EE slot power only | 320Gig WD pata Boot Windows 7 64bit | 2X160 GB Raid 0 WD Boot Vista 32bit | 2x250 GB Raid 1
CPUs are like stock PAST PERFORMANCE IS NO GUARANTEE OF FUTURE RETURNS-in other words, Expect No OC and be happy if you can OC!!!!!!!
Old 06-01-2010
i was going to suggest uei dt302 but tenma is much much cheaper..ehheheh i think you'll be fine with that thermometer...
Old 06-01-2010
Archer's Avatar
Do you have any suggestions as far as more testing that can be done that would be helpful to the average person not using extreme cooling? I hate to just post the same thing in two reviews. Makes me look bad
Old 06-01-2010
oh..that...
1. use realtemp or coretemp..they log temps...
2. use two thermocouples from the thermometer...one on the ihs(there is some space there)..the other on the side of the ihs/heatsink contact.....
you'll have plenty of data..doing 12 threads if you have a 980x..
Old 06-01-2010
remember to measure and include ambient air temps too
Old 06-01-2010
Archer's Avatar
oh..that...
Thanks I did not think do that That would show correlation as a factor, great.
For tests that involve two points of contact and ambient is a factor I use a Tenma 72-8540. It is my meat thermometer and used as a control thermometer as well.
Did you see somewhere in the review where I missed this?
Old 06-01-2010
ohhh I totally misinterpreted your post lol im sorry disregard
Old 06-01-2010
Archer's Avatar
Not a problem. I am looking for more ways to show this off. I think everyone serious about computers should have some type of thermal testing equipment.
Old 06-25-2010
Archer's Avatar
Default This is what I got for air cooling
http://bit.ly/cRb6b0
I am looking for other types of testing as well.
Old 06-25-2010
your testing methodology is unprecedented and amazing in everyway. Repped
