Old 05-26-2010
Cecil Cecil is offline
Cecil is just getting started
Default Dfi lp lt p35-t2r
Found one really cheap, and grabbed it to replace the P5B-Deluxe. Im not a DFI person really, any tips to what half their names mean
For the GTL refs, it starts at 100, and you add percentage I guess. How does that work? I was spoiled by Gig boards back in 775 days that changed them for you with the VTT
The layout around the CPU is really bare. Im going to try to get a thermometer soon and some insulation gear to put my Cedar Mill under DICE.
New Sig To Come
Old 05-27-2010
No idea bro, haven't wondered past EVGA and Asus thusfar. GL
Old 05-28-2010
good luck those boards need a 3000 page manual
Old 05-29-2010
Sorry, can't remember their terminology off hand.
I tried a celeron cedar mill on a p35 DK. Word of warning: clear CMOS defaulted FSB to 200 (which was 5GHz on my CPU). It allowed adjustment down to 133 as long as you could get into BIOS at 5 GHz. Wouldn't be an issue with a P4 though.
Old 05-29-2010
Ive got to know it a little bit. Getting an error in PiFast that I cant figure out though, says something about P not doing something. At first I thought it didnt want the ram how I had it (1030 4-4-4-12) but that wasnt it. And running ~1.65v to an Allendale E6300 for 3.6.
Other then that, I was able to push the E6300 a lot further then the P5B-Deluxe wanted to go. And I got an option for performance level now lol.
New Sig To Come
Old 06-28-2010
Got a lapped Q6600 G0 in it now, aiming for 4.2 benchable.
New Sig To Come
Old 06-28-2010
you have to start freezing stuff cecil!!!
Old 06-28-2010
I know. Just dont ever have the time for it. Bought a cooler the other day to motivate me to get in to taking the evap out of my AC.
Got the Q6600 at 1.45v 3.6 sub 40C load so far.
New Sig To Come
Old 06-29-2010
cecil do not get dice or ln2 gear, it will ruin your life trust me
Old 06-29-2010
why do you say that ?? i wanted to get a cpu pot lol
also GL ceecil i been trying to get time to fire up my ss and a p4 & p5b dlx which i havent used in like 2yrs lol
