Overclockaholics Forums » Overclocking Section » Extreme Overclocking » MaadDaawg's Quest Fatboy'd 480 thread
Old 05-21-2010
Talking MaadDaawg's Quest Fatboy'd 480 thread
Ok, just finished the "dry" run and everything seems to work okay, except one parameter I'm not sure indicates a fracked GPU mount, or, is the result of the huge fatboy pot on the CPU.
Both started at room temp at bootup, and the CPU temp started climbing as usual. The GPU temp however, started climbing VERY slowly. The CPU was at 43C by the time the CPU hit 30C. Cpu at 48C, fatboy at 31C - which seems to be an improvement.
I'm only used to the thin teck 9s so maybe this is to be expected?
Posted a couple pics on the HUMONGOUS thread, a few more coming here. Can't really put this bad boy to the test after dinner tonight (date nite with the wife .. how effin sweet is that huh : )
The pics didn't really order as I had hoped, to help tell the story. First I layed a shop towel over the mobo with a slit cut out for the pcie slot, this I then taped down as in pic #2. The towel extends to the end of the mobo as in pic 1. Then, I put down a layer of frost king (pic 3), cutout to fit from the card edge to the end of the mobo. Over THAT, I put another layer of shop towel and taped it to the pot to secure everything in place.
Pic 4 shows the dry run with both pots empty, the Fatboy ringed with shop towel and tape to hold it in place. I usually use rubber bands, but, couldn't find any in the house
So the rig sits as in pic 4, waiting for TIME to start pouring cold juice into those big, hungry, cavernous openings and going for the SR2
The 2 fans are 3 bladed deltas that push something like 125cfm. I forgot to anchor them down when I first started it up and they both flew right off the board back at my hands ... phwew.. a close one :
More to follow
Let me know about your fatboy heatups w/o LN2 in it, I'd be curious to know if its normal, or if I need to remount... tks
Old 05-22-2010
Finally got to take her for a ride today Unfortunately my dewar had been sitting for almost two weeks so couldn't bench as long as I'd have wanted to, but... wtf you going to do. A couple of decent 03 runs, nothing that will win me that SR2 so VMod here I come
GPU CBd at about -67C but didn't slow down, just died. Was running the CPU at about -155C w/o a CB so was gonna test it lower but ran out of juice.
Old 05-22-2010
Fun stuff. Nice CB on that CPU. Good lookin bench setup, too.
Old 05-22-2010
Jor-El's Avatar
Jor-El Jor-El is offline
Killer setup maddog, now it's time to catch Dent and Dom on the SR2 contest!
//RETIRED OVERCLOCKER//
Old 05-22-2010
Thanks guys
Planning on doing the volt mod either tonight or tomorrow. No mas LN2 until Monday the earliest
Old 05-23-2010
great job, how much v to the gpu?
Old 05-24-2010
I'm thinking it was about 1.375
Old 05-27-2010
Nice work dawwg. What's everyone else giving for voltage?
Old 05-27-2010
So far, 1.43 is max I've given, but less might be better. Fermi + 980x gobble up so much LN2 I haven't had much time to tweak.
Old 05-27-2010
Im @ 1.25v for 1150 core, 1.7v for 1180 mem
