Overclockaholics Forums » Overclocking Section » Volt Mod's » GTX 480 hardware vmods
Old 05-20-2010
TiN's Avatar
TiN TiN is offline
Hardware Nightmare
TiN is just getting started
Default GTX 480 hardware vmods
Do anybody need?
No, i dont have these, but it's not much hard to discover.
It's easy if you have card. I dont
So if enough people want that, we make it remotely (I mean smoking out brandnew card )
All I need is voulonteers, with good digital camera for macro shots, GTX480 card and good DMM, able to do basic measurements.
Old 05-20-2010
Deux's Avatar
Deux Deux is offline
Deux is on a distinguished road
Originally Posted by TiN View Post
Do anybody need?
Let me know what info you need, full macro shots incoming in a few minutes
If these two don't get the job done, there appears to be another one on the front, would need to pull the heatsink to confirm though.
Old 05-21-2010
TiN's Avatar
TiN TiN is offline
Hardware Nightmare
NapalmV5 from XS already done some
Old 05-21-2010
TiN,
What are your feelings on these caps for LN2 on the 480?
Nippon Chemi-Con
Appearance: Radial Lead
Series: SMG
Rated Voltage: (V) 16,DC
Rated Capacitance: (µF) 3300
Tolerance: (%) -20 to 20
Category Temperature Range: (degC) -40 to 85
Life Time: (h) 2000
Impedance1: (20degC/100Hz) (mΩ) 0.24
Impedance2: (-10degC/100Hz) (mΩ)
Rated Ripple Current1: (mA r.m.s.) 1655(Ctgy Temp(Max),100kHz)
Old 05-21-2010
16v electrolytics are big
use 6.3v rated caps...
Old 05-21-2010
IDK man... usually when 16v caps are used they are on a 12v circuit.... 6.3v caps shouldn't work for that...
Old 05-21-2010
TiN's Avatar
TiN TiN is offline
Hardware Nightmare
Not bad caps, but Sanyo OSCONs better (Violet can / marking)
Use 6.3V or 4V rated caps for Vout lines (core/memory both).
16V rated for +12V input caps
Remember : better to use two smaller caps together soldered , than one big. ESR,current with two capacitors (or more) will be better. Do not forget to put lots of ceramic capacitors. I sometimes use tantalum too, but must be careful with them, if you use them wrong polarity/overvoltage (Tantalum caps have PLUS marked, in contra from MINUS marked on regular can caps) they will burn your PCB to HOLES.
UPD: Evil :-P smile is here
Old 05-21-2010
most high end power supplies have already very good ripple suppression...on the 12v rail
cap mods on videocards are for v_core and v_ram
Old 05-21-2010
I have a few OS-Con's but no 16v ones.
Old 05-21-2010
those look like 4v...
it should work for vcore and vmem....
