Old 05-14-2010
Cecil Cecil is offline
Cecil is just getting started
Default Wprime, What Am I Missing?
http://hwbot.org/rankings/benchmark/...ypeId=CPU_1935
Running faster then everyone but the top guy. Ram timings doesnt seem to make a difference, cause 4-4-3-8 didnt help. Running the 32bit XP xtreme that was linked in the other thread.
Its the same thing with the other CPUs Ive been benching. Spi and Pifast I kick ass with even lower CPU speeds then others, but wprime I cant do shit.
New Sig To Come
Old 05-14-2010
AMD clocking aint my bag but can you increase HT speed?
Old 05-14-2010
Not really, already pushing what it can do. Plus one of the 3.4 guys is running HT slower then mine.
New Sig To Come
Old 05-15-2010
What OS tweaks do you have going on?
Old 05-15-2010
display driver installed?
Old 05-15-2010
For 32m I usually run 3 threads on AMD ...
For 1024. only 1 per core. but I use the same tweaks as for spi32. LSC, MAXMEM and diagnostic mode. Spitweaker is a nice tool that cleans your temp files and also runs copywaza for you. Can try that.
Old 05-15-2010
None, just using the XP install mentioned above.
No.
Guess Ill give that a try.
New Sig To Come
Old 05-15-2010
Gutterz's Avatar
Gutterz Gutterz is offline
Display drivers are your problem. Install them. I had the same issue an Splave told me to install them an I did an it fixed the problem. I never did thank you Splave, Thanks. Sometimes u get wrapped up an stuff an keep thinking inside the box.
Old 05-15-2010
Just gave that a try. Using an x1650XT and tried the 10.2s, and it made no difference
New Sig To Come
Old 05-15-2010
Jor-El's Avatar
Jor-El Jor-El is offline
Are you assigning threads?
//RETIRED OVERCLOCKER//
