Old 05-14-2010
Question What's FUBAR
I have an idea, but thought I'd throw this out and see if you guys (and gal) can save me some from the tedious task of trouble shooting a wc rig
My gamer.
Slower than fuckin molasses in winter. Started a few days ago when I flashed the BIOS. Flashed it again today and no improvement.
Symptoms:
slow, as per above
HDD light CONSTANTLY running effing wild
Hanging up intermittently
BSODing while gaming .. before it slowed down this much..
The ECP displays temps at stock speeds, ONLY FF when OC'd to 4.5g
Hardware:
i965 EE sitting on a wc EVGA 769 (760 /w hydro copper wc block)
Caviar Black 500g, 3x2g Gskill Perfect storm 2000mhz RAM, tri sli 285 evga HC cards
Suspicion:
HDD, BUT, that wouldn't explain the behavior of the ECP display
Second potential culprit on my list - THE CPU
May be the mobo?
Could be the OS needs a fresh install
I've had to stop 5 times now and wait for the system to come back while typing this, and I'm at default speeds.
I started the restore wizard before I started typeing this, and it's still not starting?
Your thoughts????
Old 05-14-2010
My friend, I have reason to believe your frag box has the AIDS.....
Can you run a Hijackthis?
IF not, run in safemode and look at your startup list and post what is in it verbatim...
Old 05-14-2010
I would start with a fresh install of OS and see what the outcome is.
Old 05-14-2010
AIDS??? OMG Face, wtf is a hijackthis??
I went through the startup hours ago and didn't see anything out of place. I have a heavy duty virus suite so at least for the moment I'm not thinking that's it... actually this happened though last night when I switched off while playing UT3 with the supes Since then it's been dead ass slow.
I'm shying away from a fresh install only because it's an OEM disk and I'd have to wipe all my gaming files off and reinstall - not ruled out though by any means.
Actually, I'm hoping it's the processor so I can RMA it :
Restore finally started just after my first post, and it's still initialing as I type this.. doesn't look promising
Maybe I'll swap the whole damned thing out tomorrow morning
sure as hell ain't happening tonight
on the lappy
Old 05-14-2010
Well, the restore seems to have done some help. Went all the way back to 5/5 but do think I need a fresh OS install soon. The ECP is displaying the CPU temps with the rig running at 4.4 ghz.
Not sumthin I can RMA the CPU over huh... bummer lol
Any thoughts, please, keep em coming
now for the real test... UT3
Old 05-14-2010
enozo73's Avatar
enozo73 enozo73 is offline
enozo73 is just getting started
I agree with DrNip, a fresh install. From there if you still have issues you know it is hardware.
Besides a fresh OS install never hurt anything IMO.
Q6600 24\7 @ 3.2 on air
EVGA 9600GTs in sli
XFX 780i
OCZ RAM
and I can't remeber everything as it has been a long time since I messed with any settings or changed any parts out.........
Old 05-14-2010
Sounds like an infection or possibly a bad driver/update.
Reinstall should fix you up nicely..... Cleaning/fixing from where you are now doesn't typically yield as crisp results...
....stay off the pr0n homie...
Old 05-14-2010
I remember you disabling your a/v suite in an attempt to survive the battery of rockets sent your way, just wished it woulda worked out better for yah
Keep tinkering, I'm sure you'll figure out wth is borked.
Old 05-14-2010
: yeah, you were kickin my ass and I had to do something :
Agree with all on the fresh OS need but at least the restore got the rig running at it's old pace again. Played some UT3 on the Dawgg server so I wouldn't be embarassed by the Superbro again should something go wrong
Should be ready for the UT3 blowout this weekend, just let me know the schedule
Old 05-14-2010
Anytime Sunday is the schedule, be there or be forgotten.
