Overclockaholics Forums » Hardware Section » Motherboards » Intel » e762 post code 62 at cold boot
Old 05-05-2010
Default e762 post code 62 at cold boot
Very strange, with the A0 locked and loaded I get F3 F6 F3 62 and hangs on 62. Thought it was CBB but at same settings its moving around 20+c. Sometimes I can boot -118 sometimes it takes -89 to boot. Very weird. Also after a BSOD or freeze the reset button is unresponsive then it will shut off and on reboot it will post F3 then cut power, F3 then cut power and will keep doing this till I clear cmos.
BTW with the A0 it defaults cpu pll to 2.05v
This chip is very illogical, and completely random but nasty as fauk
I ran out of ln2 in my pitcher and had to head to work so I was at -85c and for fun it passed pifast at 5.9ghz 1.75 volts rofl.
Old 05-05-2010
Maybe try one of the older beta BIOS made for the A0's? Kal has a good one he could send you.
Old 05-05-2010
would be great
Old 05-05-2010
The newer BIOS defaults to 2.05 for some reason when the jumper is moved. My 759 does it too.
Extreme Cooling Mode for Classified Motherboards – BIOS shows 2.055v CPU PLL when X-Cool jumper is moved (1.60v Real)
http://kingpincooling.com/forum/show...76&postcount=1
Old 05-05-2010
oh cool so thats normal
Old 05-05-2010
Yup, my 760 shows the same.... using bios 56.
Old 05-05-2010
still worried about 62, its annoying as hell.
Old 05-05-2010
PM Kal for that BIOS he uses. He loved it.
Old 05-05-2010
Gutterz's Avatar
Gutterz Gutterz is offline
What jumper on the 759? the CSC Strap by the dimms?
Old 05-05-2010
The jumper beside the NB and behind the memory dimms. X-cool I think is what it is. Has anyone played with the strap jumper?
