Old 05-01-2010
Default RocketDock
Give it a try if you havent already...very handy!
http://rocketdock.com/
Old 05-01-2010
If you want OSX want not just install OSX?
I like new things... but rocket dock is like 10 years old. Aston is as well if you want a total explorer replacement. Too much work for me and not enough return.
I mean really.. I cons that enlarge when you hover over them? Is that a cool feature? Maybe if your mouse does not track correctly... so you know where you actually are...the other benfits I read most come built in to apps (minimize to systray for example or its a simple reg hack)
Old 05-02-2010
Well, it is new to me as I have never used it before. It is especially appealing to these old failing eyes. Too much work? It installed instantly and works flawless...I could'nt find a fault in it myself.
Old 05-02-2010
I meant the theme changer was too much work LOL
I did not think about the easy on the eye thing. Some positive in it after all
Old 05-03-2010
Used it a while ago. Then I just started lining my icons up across the bottom of my desktop...one less thing to install lol.
