Overclockaholics Forums » Hardware Section » GPUs » ATI » Need help looking up 4870x2 Asus top bios.
Old 04-29-2010
Kriztoffer's Avatar
OC Alliance
Default Need help looking up 4870x2 Asus top bios.
*EDITED* Modified 4870x2 Asus TOP bios, one with slight more voltage and stuff.
I can't find the bios I'm looking for. And I'm sure there are someone sitting on this bios
the bios should be around 790/915 defult or something.
Since we all know the 4870x2 is a dual-gpu card I'll need one master and slave. I got this HIS 4870x2 from release days for cheap, I've had some problems with it, and stuff. so I baked it for 7min, and seems to be running fine now.
But I'd like to get it onto a different bios, stock bios is shit!
Best Regards Kriztoffer
slipping the clutch
