Old 04-22-2010
Question Is this normal
Installed my GTX 480 and presicion is reporting a clock speed of 1451. GPUZ reports a clock speed of 725. The GPUZ report corresponds to the cards stock numbers, but Presicion is reporting double ???
Any one experiencing this?
Old 04-22-2010
Yup got the same thing. Hey what the hell is that black foam thing n the back for> I hope i can take it off to insulate.
Old 04-22-2010
lol.. I was wondering the same thing lol didn't really notice it until the card was mounted on the board and then I though "oh shit" part of the packing material.. it'll catch of fire :
Glad I'm not the only one
Thanks Bro
Old 04-22-2010
No ln2 until Monday so i've got it on my gaming rig having fun with it. Also lurking forums for tips and making my strategy. I'll insulte it on Sat and Sun. waiting for heatsinks to come in from Frozen. I wish i had a 2nd pot. i have my 2nd coming tomorrow.
Old 04-22-2010
You need the latest precision ... get the unlocked one from the ftp
Old 04-22-2010
Is the latest one working? I had issues with setting the memory one the 470 with it. For some reason it would always jump back to stock after I applied it. I ended up using the Galaxy tool.
Old 04-22-2010
This is the one from the ftp. Whats this? It wouldn't install.
Old 04-22-2010
you can remove the foam from EVGA cards and not void the warranty. However other manufacturers that may be different.
Old 04-22-2010
Ok i had to extract the file to desktop from winzip to get it to work.
Old 04-22-2010
maddog
did you install the newest version of precision? the older version will not read anything but temps correctly.
as for the skin, sometimes it will not default to the correct, if thats the case then you can manually apply it under the wrench icon, then under user interface.
