Old 04-21-2010
Default which webcam ?
I need help finding a webcam for livestrems for around $30
limited to newegg
Old 04-21-2010
limited to newegg
Ask Hondacity or V2-V3. The one they have used in their live stream produced nice pictures i think.
Old 04-21-2010
I keep seeing this one come up on reviews but its a little high in price
http://www.newegg.com/Product/Produc...82E16826105226
They have the same one on amazon for $30 with free shipping, going to live chat with newegg maybe i can get a price match.
Also found this one
720p with micro phone
http://www.newegg.com/Product/Produc...feCam%20Cinema
Old 04-22-2010
You said you are limited to $30 but go with the Microsoft HD. That is the one I have and the one I was going to provide a link to you. Top notch camera.
Old 04-22-2010
I just picked up the Rosewill Black golf webcam for $20 and comes with free usb numberpad (doubles as a 2 port usb hub)
Image looked surprisingly clear but are limited to 640x480 at 30FPS.
Should be up on livestream tonight
Old 04-22-2010
I saw a comparison between the life cam and the logitech 9000
they said the life cam is a resource hog but it is cheaper
Around what time ?
Old 04-22-2010
Around what time ?
Hoping to start around 8:30PM EST.
Old 04-22-2010
Russianhaxor's Avatar
Russianhaxor Russianhaxor is offline
Russianhaxor is just getting started
MicroShart and Logitech are your best bets...
I have the most uber webcam you can buy, but its pointless for you
Old 04-22-2010
There are alot of great webcams out there but when it comes to broadcasting a show you are only limited to whatever they offer for free broadcasting. To broadcast in high def you are going to have to pay a hefty membership premium. You might look into getting a separate mic one day as pretty much all mics on webcams blow. Newegg has a pretty good one for $20.
Old 04-22-2010
Gutterz's Avatar
Gutterz Gutterz is offline
The real test is viewing the FPS counters in the benches, most cant define the numbers. For those who have web cams should try an post back with the camera you have.
