Old 03-25-2009
spfoam1's Avatar
spfoam1 spfoam1 is offline
Lurker
Default wPrime
Here are two wPrime runs. Both were done with an E8500 CPU on an Abit IP35 Pro board. Both were done at exactly the same CPU and RAM settings. The only difference between the two is the number of threads the benchmark was set to run. I ran both several times to be sure the score was not abnormal for any reason.
This one was set at two threads
This one was set at 4 threads
Old 03-25-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
I tried that and got a higher score.:confused:
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 03-25-2009
Yeah for some reason it runs better on 4 cores even when you have a dual core.
Old 03-25-2009
Jeffro64's Avatar
Here's a little better... but only at 4 threads.
Main Rig
Old 03-25-2009
Hey, that looks like good voltage bud for 4ghz on that chip. You might have a keeper.
Old 03-25-2009
Jeffro64's Avatar
I think it will go a couple below that.... I think I raised it up trying to figure out that BSOD issue I was having and never put it back down.
Main Rig
Old 03-25-2009
Komadyret's Avatar
Komadyret Komadyret is offline
Komadyret is just getting started
Good to know I'm not alone in this, I have looked briefly into this wprime stuff myself.
In Vista at stock speed my E8400 acctually had it's fastest wprime with 16!!! threads, consistently.
With a 4.5GHz OC it ran fastest with 4 and 6 threads. Couldn't really find any consistent winner, but optimal threadcount was much different than for stock speeds.
My point; the optimal thread count is different for different chip-architechture, and it changes with the overclock of the cpu. This bench needs a few runs at various threadcounts to establish where it will run best. Also keep in mind that you should run it at least 4 or 5 times. Sometimes run #2 or run #3 or run #4 will go considerably faster (~1/2 tenth of a second faster for a core2 duo?) that the others.
Old 04-23-2009
Just a heads up, on the i7's run it with a 8 thread count as it beats out the 4 thread count.
Old 07-10-2009
G H Z G H Z is offline
G H Z is just getting started
wPrime is not consistent (like all other benchmarks) only the differences are somewhat amplified because it's running 2, 4, 8 or more threads. I do have one team mate who swears by the over-threaded approach.
Old 07-10-2009
crustytheclown's Avatar
EXTREME NOOB...
That makes two of us - I also know a guy who is an avid supporter of the over-threaded approach.
