Old 04-11-2010
Default GTX 470 Voltage Mod
For all the following modifications, use multi-turn potentiometers for best control over the voltages. A suitable ground reference point would be the 12V PCIe power connector. gtx470_Vmod.jpg
Source: VR-Zone
Old 04-11-2010
Old 04-11-2010
Now, if you could only find the cards for sale ;(
Old 04-11-2010
I'll have on on Tuesday! The pot is waiting already!
Old 05-04-2010
PizzaMan's Avatar
PizzaMan PizzaMan is offline
PizzaMan is just getting started
I'm still waiting to see one of these bad boys modded.
The 480 is temp limited like the 200 series, but extra GPU voltage seems to help stablize high mem freq. I'd bet the 470 acts the same way. I wonder if vDDIC is tied in with the GPU core voltage.
Old 05-12-2010
The 480 is temp limited like the 200 series, but extra GPU voltage seems to help stabilize high mem freq. I'd bet the 470 acts the same way. I wonder if vDDIC is tied in with the GPU core voltage.
Here some pics of my mod. It aint pretty but who cares if it works!
Old 05-12-2010
nice see you added the pll, any gains?
Old 05-12-2010
Watchya talking about "not pretty". That's a feast for the eyes. And you even used shrink wrap!
Old 05-12-2010
PizzaMan's Avatar
ummm, some tasty work there. This makes me want to plug my iron in and mod something.
Old 05-12-2010
Man you got some super clean joints!! How the heck do you get your joints solid enough to press eraser over them without breaking them? WTF am I doing wrong. Mine are always fragile as hell. You solder skills are pro for sure.
