Overclockaholics Forums » Hardware Section » GPUs » ATI » Problem OCing 5870
Old 04-09-2010
Default Problem OCing 5870
Sapphire Radeon HD 5870
Cat 10.3
Extreme Afterburner
Can go no higher than about 1000/1301 at 1.33 volts. Tried Rev's suggestion of lowering mem but still no go. Every time I try to bump it up in Afterburner it just reverts back to default settings or bluescreens.
Old 04-09-2010
What is the GPU temps .... That has to be what is holding it back ....
Old 04-09-2010
Showing 44 right now at 1000/1301
Old 04-09-2010
Do you have both these checked in the settings?
Old 04-09-2010
That does not seem that high ???
Old 04-09-2010
Switch drivers yet?
Old 04-09-2010
Yes, they are both checked OC. What driver should I try?
Old 04-09-2010
To try and find if the drivers are the problem I would start at 9.12. I had a problem getting 10.3 drivers and AB-E to run with my Gigabyte card. Switched to 9.12 and worked fine. That was just my experience tho.
Old 04-09-2010
Try AB 1.4 it worked with 10.3 beta's for me
Vantage and 06 are much better with the 10.3 for me
9.12 for everything else
Old 04-09-2010
Seems that is just all this card has in it. No matter, not complaining as it is going in the gamer soon.
