Old 03-25-2009
Default GTX 285 Volt Mod
http://www.xtremesystems.org/forums/...=215224&page=4
Old 03-25-2009
Red = vgpu measure point, green = vmem measure point.
Old 03-31-2009
GTX285 VGPU and OCP mod
Here is the VGPU mod for nvidia GTX285 to start with, I will update the thread as soon as I have the OCP mod image done.
I will also post some more info from our Tri-SLI benchmarking at CeBIT 2009.
! IMPORTANT INFORMATION !
These mods have been tested, BUT I take no responsibility for how you use
the mods and what happens to the card. Make sure the cooling is sufficient etc.
The soldering order is crucial, make sure it's done exactly as the images show.
This is how it looks when soldered to the card.
We ran 1.4V+ and no sign of OVP.
OCP will trig at some point and here is the mod for that:
Old 04-28-2010
Time to bump this thread up. Has any of the guys here modded a 285? I just got one in the mail today and she needs some resistors Which one's did you guys go by? NapalmV5's or Crotale? Also I take it Napalm's vmem mod is the correct one? Splave....OCGMJ???? Anybody?
Old 04-28-2010
I prefer
Old 04-28-2010
That's vmem. Which vgpu do you think is best? Crotale? That one is a little more advanced.
Old 04-28-2010
Which version PCB do you have?
Old 04-28-2010
Heck if I know. I'll post that up when I get home. If its too complicated this puppy is going to you barring you have the time to deal with it.
Old 04-29-2010
Alrighty, the PCB is the one in the pics above. The mods other than the OCP seems pretty darn easy. I'm just worried about the OCP and Vgpu being so close. Either way I'm gonna order the trimmers for all three mods.
Old 04-29-2010
I would hold off on the OCP till you find out if it hits. Just my 2 cents
