Overclockaholics Forums » Overclocking Section » Overclocking » Modded P5B-Deluxe with P4 631 Cedar Mill
Overclocking Air & Water...
Old 03-28-2010
Cecil Cecil is offline
Cecil is just getting started
Default Modded P5B-Deluxe with P4 631 Cedar Mill
Finally got a hold of a P5B-Deluxe for cheap, that just so happens to have vcore and vdimm mods already done. Also got a couple sets of Gskill HZ D9s for cheap as well.
Have a P4 631 for testing. Wasnt sure where to start first since Ive never toyed with P4s, so I bumped up to 266FSB, 1.45vcore, 2.1vdimm, 1.45NB. That went smoothly, so now trying 280FSB, same volts. Ram is at 933Mhz 4-4-4-12. Testing with Intel burn test to see where Im at. 52C load so far.
Going to see where I can get with air, then put it under water. Once Im tapped out, Ill try it out with DICE when I get a chance.
Here is my bench setup till I get a loop going. When I do, the rad will be mounted to the AC.
DFI SLI-DR in the pics.
http://s864.photobucket.com/albums/a...hing%20Setups/
New Sig To Come
Old 03-28-2010
what multi you using? cpuz please
Old 03-28-2010
Just using the stock x15. I dont know if its the board, or the BIOS, but there is no option to change the multi
Got up to 286x15 with the same volts as above to pass burn test. Im aiming for 333 for 5Ghz air
Here is a 32m wprime I ran at 4.2HT. Its nuts how slow it is
New Sig To Come
Old 03-28-2010
it is old technology...but with dice 6ghz is possible...hmmm multi should be higher though
Old 03-28-2010
Wow... and I thought ATOM sucked.. I forgot about Pee4 LOL
http://hwbot.org/community/submissio...min_39sec_46ms
1m 39 seconds at 2GHz atom processor
geez man.. new props for a smart phone processor i guess.
Old 03-28-2010
Its a 631 3Ghz, 15x is right.
Might be getting another Cely 356, NIB. Not sure yet.
New Sig To Come
Old 03-29-2010
347s are what ya want!
Old 03-30-2010
4.5HT benchable with air
Still slow as balls, but it seems like a good OCing chip. 1.48vcore, 1.4vtt, 1.45nb, 2.25vdimm. Ram is at 1000 4-4-4-12, definitly the best DDR2 Ive run. Will post benches once Pi 32m is done.
EDIT: Pi 32m BSOD :(
New Sig To Come
Old 03-30-2010
Cedar Mill 631 max multi is 15
