Old 03-24-2009
skarface's Avatar
skarface skarface is offline
skarface is just getting started
Default Over clocking software
Alright i was taught/told that it is much better to oc hardware like ram and the cpu through the bios vs lets say through nvidia software in windows. Is there any difference vs ocing something in windows than doing it in the bios? How does everyone do it here?
raid 0 seagte baracuda 320s
seagate baracuda 500 gig
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
mushkin redline 6 gigs (pc 16000)
corsair dominator fan
2 koolance reservoir 1 magicool reservoir
2 cpx pro pumps
koolance 330 cpu block and koolance video blocks
stealth ice gt triple rad
black ice steal gtx extreme 240
heatware
Old 03-24-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
I was told the same thing so I do it in the bios.
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 03-24-2009
skarface's Avatar
yea i was just curious because it would way easier to do it in windows than the bios!
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
2 cpx pro pumps
heatware
Old 03-24-2009
I say overclock in BIOS mainly but if you want to squeeze a lil more out of your cpu then use setfsb in windows, if your mobo allows for it. The advantage of doing that is you will be able to squeeze a lil more out due to not having to go thru the boot which causes alot of heat. GPU's you have to use software unless you modify the card.
Old 03-24-2009
hellcamino's Avatar
Definitely use the bios for overclocking your cpu and ram with the only exception being setfsb for that last little bit you are trying to get for a bench. Using setfsb at that point is ok as you are already pushing your system to the very edge of it's capabilities and breakage isn't just a possibility anymore...it's a probability!
If you are looking for a 24/7 cpu+ram overclock then it's bios only! The reasons are simple:
Anytime you overclock, instabilty becomes likely and must be alleviated through testing and bios adjustments. If you just change your clock speed in windows using some ghetto software tool you will not only likely corrupt your os but you will corrrupt the bios as well!
When you alter a bios setting within windows you are assuming that the system is stable to begin with, if the system isn't stable and you adjust your bios this way you run a high risk of corrupting your bios and bricking your board and the os is almost guaranteed to be screwed up. I myself don't even use setfsb as I don't push my hardware to the point of likely failure, If attempting to break a world record....ANYTHING goes!
Video card overclocking has to at least initially be done with software and after testing can be flashed to the card, not all people are comfortable with flashing their cards but I at least am a fan of it. You will get slightly better performance with a flashed overclock due to cpu clocks being freed up and you are no longer relying two pieces of software (driver+oc software) to maintain stability to run your cards.
Old 03-24-2009
skarface's Avatar
Thank you for that very informative!!
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
2 cpx pro pumps
heatware
Old 03-24-2009
hellcamino's Avatar
No problem! As long as you can learn from others mistakes you are way ahead of the game...I learned the hard way.
Old 03-24-2009
Jeffro64's Avatar
How hard is it to flash the video cards? I didn't know that could be done.
Main Rig
Old 03-24-2009
hellcamino's Avatar
It's very similar to flashing a motherboard, in my case I had to do it twice for each card: once for each primary gpu and again for each secondary gpu (4870X2's) but for single core cards it is very simple.
Old 03-24-2009
Jeffro64's Avatar
Hmmm, might try that if I ever find a high enough stable OC for my 280's.
Main Rig
