Old 03-21-2010
bartx bartx is offline
bartx is just getting started
Default 1HP Rotary Cooler
Hello everyone,
In fact it's my first serious unit. It took a lot of time to build this, but it wasn't wasted time
Just an ordinary, quite strong SS. I'm pretty satisfied with the results (-41C @ 250W, -46C @ 180W, -54C @ idle). Maybe it can be tuned a little better (it also depends on where K-type probe is located, I've drilled small hole on the top of evap, bcoz for now I'm mostly interested in overclocking, not the lowest temperature ). I've tested it few days ago, and on E8400 @ 5,2GHz 1,8v there was something like -48C what is nice
Compressor - Teco KETC176 10755 btu
Condenser - 25x25x5cm, 4x 120x38 mm Nidec fans (10V, 0.5A each)
Suction line - 80 cm long, 19 mm thick insulation
Evap - stepper, 42 mm diam, 40 mm, my production
Expansion valve - 0,8 mm captube
Refrigerant - pure R507
Baseplate - stainless, 35x50 cm
Some frost (about -54C on idle)
250W load
Old 03-21-2010
Very nice work! Doesnt get any cleaner than that
Old 03-21-2010
Hey BartX nice to see you over here (was just PMing you over at OCN)
Sweet looking SS you have there, very clean
Old 03-21-2010
Nice and tidy build bartx, what was your final material cost?
Old 03-21-2010
Sweet build man
how does it hold on 1024 ?
Old 03-21-2010
Very clean! Is there a switch hidden someplace?
Old 03-21-2010
Very nice clean unit mate! I love it!
Old 03-21-2010
Geez my intertubez is nuts today! For some reason it always double posts!
Old 03-21-2010
RomDominance's Avatar
Immaculate work Bart, and it looks like it performs well to boot. BTW, welcome to OCA, hope to see you around more.
Old 03-21-2010
beautiful build bart, can't wait to see what it does strapped to a cpu.
