Old 03-21-2010
Default bartX pots
Anyone used his pots before?
http://www.bartxstore.cba.pl/
Contacted him for prices and seems pretty reasonable considering the weight.
Pot 2.0E costs 80€ + 22€ shipping
Pot 2.0M costs 120€ + 34€ shipping
Pot 2.0H costs 160€ + 39€ shipping
(times 1.37 for USD)
comes to about $140 for E and $200 for the M. H is way up there at $280
Old 03-21-2010
Gutterz's Avatar
Gutterz Gutterz is offline
H dont look to great, to me it seems like they took to much mass out. I think I may make one myself I know plenty of people in machine shops.
Old 03-21-2010
I think those are great pots. I know Chew has one he uses from time to time and loves it.
Old 03-21-2010
Rich, would you like this moved to the sub-zero section? The cold spot is for VIP access only.
Old 03-21-2010
A sure...
Thats probably a good idea thx
Old 03-21-2010
bartx bartx is offline
bartx is just getting started
Just for the info - some scores using my pots About 2.0H - maybe you didn't notice it, but outer holes are connected with center hole which provides very good distribution of ln2. I you think that surface area is a bit to small, will be improved in next rev. for sure
http://www.benchtec.co.uk/forums/showthread.php?t=5807 2.0H
http://www.benchtec.co.uk/forums/showthread.php?t=6110 2.0M
Old 03-21-2010
i would really like to try your pots..but they're too high....cbb fight would be difficult...
Old 03-21-2010
I can make custom projects too. You mean, that you rather want solid design, about 15 cm, because it's easier to use torch to warm up the pot? If so, there is no problem.
Old 03-21-2010
Hey sorry Bartek.
Was looking for an objective opinion. Your pots certainly look good by specs... I am kinda new to all of this so wanted a worldly viewpoint
IE some that has used Vinces pots and Dunileks. and could compare the differences for me
$200 is kinda a big investment for cooling and TBH one I should not be doing..so getting a 2 M is a big step for me...
(Especially since I just learned you dont just fill the pot with DIce lol and more importantly WOW acetone is so much better than 99% isopropyl :p)
Old 03-22-2010
ahhhh i'll pm you if i'm not happy with an incoming pot from andi(otter), i saw the_goat_eater's pot its was really nice. i think you made that pot for him. good to have you here
Hey sorry Bartek.
dude i started with acetone...lol isopropyl.. acetone splash isn't good on the skin....sorta irritates.
