Old 03-10-2010
Default Corsair 60GB SSD
Just picked one of these up,
newegg link
Curious if it will have a problem with high BCLK/PCIE freq (limited to about 225/103.5MHz ATM I think) or should I just stick to my raptor and use the SSD in my AMD setup.
Old 03-10-2010
Jor-El's Avatar
Jor-El Jor-El is offline
newegg link
That's an excellent ssd!
I used ssds with the p55 classified with no problems or corruptions, max pcie I used = 210Mhz.
Old 03-10-2010
pcie overclocking...ummm it works..but not much effect...it does open up the bandwidth.
i suggest using ssd for benchies...dunno how it affects superpi32m though
Old 03-10-2010
Gotta raise PCIE freq to get past 222 BCLK... I thought I had seen some mentions of it causing issues with SSDs though, just want to make sure
Old 03-10-2010
yeah pcie killed my os drives lol, one vraptor..and some pos harddrives... all were sata...good luck experimenting... the classified had to be booted at 108mhz... the gigabyte x58 extreme needed pcie 215mhz to oc well... what chipset do you have?
Old 03-10-2010
x58
its the bloodrage. limited to 103.x until i do the mod...been too busy to get it done. Doubt I will hook it up tonight.. but probably should. Was going to watercool chipset and maybe 4890. Regardless I have to break down the loop to mount it on x58, rather not have to do it 2 more times in the next week. Might skip watercooling the 4890 though... since I have a few other gpus to bench...
Old 03-10-2010
DOesn't seem like a humungo problem if you image the os first. Corruption, replace the image in a few minutes.
Old 03-10-2010
Yeah the corsair drives are nice.... I actually have a X64 extreme SSD I am selling.
Old 03-10-2010
ahh the bloodrage those are superfast...i had a buddy running dangerously at 4.8ghz with ht on with a 920 on air..at 1.68v on that..lol
the guys doing damage with the i920 are using bloodrage boards...i hope you do it good.
Old 03-10-2010
need to mod it to do real damage, but yeah I bought the board after hwbot searching
