Old 02-25-2010
Default what do you guys think?
i have been doing alotta thinking and i made up my mine that i will BUY a pot for the CPU and maybe home-make a water cooling system my self to save some $$
i been looking on ebay and nashville area craigslist and found a pot on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_3057wt_1165
is the link to it, the thing is i don't know what to look for comes to buying a pot, like all i know about it really is that works with all the cpu i want it to be on and it's made by koolance
some advice please
also found this too
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_3660wt_1165
what is the dif between the first one and the second?
thanks guys
Old 02-25-2010
hey bro, the 1st one is the rev1 which is better for dice, 2nd is the rev2 which is better for ln2
Old 02-25-2010
Actually that remains to be seen with the Rev2, at least I haven't seen anything on LN2 runs with it.
Don't expect much with it on LN2.
Old 02-25-2010
how to tell between better for dice or ln2?
the first one is really $50+ less than the second one...
Old 02-25-2010
The mass of the pot and what it is made of. What you want is a massive copper pot to help control swing. Temps will most likely bounce around a lot and be hard to keep it stable. Look at the F1 and then compare.
A lot complained about the first version as its not made with a metal tube, deralyn or something like that. Some cracked and split. I might be thinking of the GPU version of that, prolly am.
The Rev 2 has a Alum tube for walls (maybe Rev 1 also), but when LN2 hits Alum it gets very squirly, chew calls it Super Nova effect LOL.
Not sure if you can see the for sale section on XS, but this pot would be an great DICE pot and could be used for LN2 also.
http://www.xtremesystems.org/forums/...d.php?t=239803
Old 02-25-2010
i just learned ALOT from that!
Old 02-25-2010
http://www.legitreviews.com/article/1190/7/
Goemler reviewed it, said that its better with dice and ln2 than the rev1. Its better at dice than the f1 even
BartX pot is nice $155 shipped
Old 02-25-2010
where can i find one of those bartx pots?
Old 02-25-2010
its on XS
Old 02-25-2010
I'll say one thing....the Rev1 is killer for DICE.
