Old 02-24-2010
Default Which is better
Rubber or conformal coating?
Price:Efficiency wise
I would think that a rubber coating might be better because it might also help with thermal transfer more than a conformal coating would... since there is a medium to help transfer heat despite being an insulator...
Any tests done on this though?
Old 02-24-2010
for the gpus I'm using liquid tape
I found it at home depot for $4 i believe
haven't done ln2 on motherboards yet so idk
Old 02-24-2010
Not sure bout the rubber bro. Be interesting to see.
Old 02-25-2010
Conformal Coating is by far the best for but motherboards and GPU's. Just paint it up and put a little eraser around the socket to make an air tight seal.
Problem is its not very easy to get off, unless you dont mind sitting the board in a tube of acetone and scrubbing away for a long time.
Generally if you plan on selling the board later or have to do any RMA's dont use it.
Black Electrical tape worked pretty well, I used it on a GPU. It was a pain to get off and it got into all the IC pin areas and was hard to get out. Most of it just peeled right off tho.
My frost picture of the back side of the GPU sucks, but I think you can see you dont have to worry about any insulation back there.
Old 02-25-2010
I was thinking most the guys were just using vasoline...easy clean up afterwards.
Old 02-25-2010
Gutterz's Avatar
Gutterz Gutterz is offline
ya vaseline seems way easier to remove. Heat it up ah hit it with an air compressor works well.
Old 02-25-2010
Gah... I totally hate that stuff. I never use it.
Old 02-25-2010
Im an eraser only type guy, so I can peel it off when I eventually break it. Couldnt be easier and no condensation issues yet.
Old 02-25-2010
+1. Easy to apply and remove, so when it's time to sell the board/card is mint.
Old 02-25-2010
So no thermal properties benefits just ease of use eh?
Maybe I will try the Vaseline than to start, go eraser later and find conformal after that.
