Overclockaholics Forums » Hardware Section » RAM » Need some 2000mhz cas 7 3x2gb recommendations
Old 02-23-2010
Default Need some 2000mhz cas 7 3x2gb recommendations
Need some fast ram for aq3 and spi32m primarily. I got burned once using the ramlist and paid out the ass for crappy IC's lol I think once the hyper death fiasco occurred most companies pulled it/ changed ic's but kept the same part numbers for the sticks.
Anyone have recommendations? Need atleast 2000 cas 7 3x2gb.
Old 02-23-2010
Gunslinger's Avatar
Overclockaholic
Corsair Dominator GT's or GTX series
OCZ Blades (impossible to find)
GSkill Perfect Storm (not sure which model number has the good stuff though)
Kingston HyperX (not sure which model number has the good stuff though)
Old 02-23-2010
so the 1866 doms are hyper?
Old 02-23-2010
I use storms that run @ 7-8-7-21 @ 4985....
Don't pay attention to the scores as I suck at SPI ....................
Can't speak to higher clocks thpough my friend as I can not get there
All tohe super new +2000 crap is loose as a goose and prolly rebranded 2000 Mhz stuff anyway
Old 02-23-2010
sofos1990's Avatar
yes corsair 1866 doms are hyper.
As Mike said OCZ Blades are impossible to be found haha
Better go with the 1866s or with the 2000s CL7. In case you want to spend more money the top choice is GTX.
Old 02-23-2010
Gunslinger's Avatar
Overclockaholic
I should mention I have the 2000MHz CAS8 version of the GT's and they'll do CAS7 with only a slight bump in voltage. Pondering 6GB of the GTX though
Old 02-23-2010
maybe?
http://www.thenerds.net/CORSAIR.6GB_...=19-36639823-2
Old 02-23-2010
Gunslinger's Avatar
Overclockaholic
Cheaper to just buy direct:
https://shop.corsair.com/store/default.aspx
Or the CAS 8's from ZZF:
http://www.zipzoomfly.com/jsp/Produc...tCode=10010960
Old 02-23-2010
The muchkin redline 2000 8-8-7 are also hypers. I think nip pulled pretty good results with his set. They are under 300 at the egg.
Old 02-24-2010
I have the ocz blades 7-8-7-20 ... love em
