Overclockaholics Forums » Overclocking Section » Volt Mod's » Kriztoffer 5870 volt mod
Old 02-11-2010
Kriztoffer's Avatar
OC Alliance
Default Kriztoffer 5870 volt mod
Been working on my 5870 today.
Things done:
Soldered 11x 470UF 6.3v Caps onto the phases.
Removed stock VR at OCP and added 18K fixed VR for OCP mod
Voltage read
GPU Vcore boost ( I'm missing the 50 OhM VR)
I'm looking for more hardcore mods! please shoot me a tip if you got one.
- Kriz
slipping the clutch
Old 02-11-2010
Add an extra 6-pin connector for input. That's about all you can do after the vmod and extra caps.
Old 02-11-2010
looks great man
Old 02-11-2010
looks awesome. Maybe an evbot mod next
Old 02-11-2010
crustytheclown's Avatar
EXTREME NOOB...
Fantastic work man!!!
Just add some caps here and you're good to go.
It will help your memory a lot at low temps...
Adding extra 6 pin can be a tricky business especially when soldering and choosing the right cables for the job so i wouldn't even mind...
Old 02-11-2010
Excellent advise crusty!
Old 02-11-2010
Kriztoffer's Avatar
OC Alliance
Thanks for for everyone taking their time to comment!
Crusty should I just use 470UF 6.3v caps for it?
I´d love the extra 6pin, can´t be that triky and I´m really up for it! if anyone have time to explain, I´ll listen carefully!
Thanks a lot for the advice!
slipping the clutch
Old 02-11-2010
EXTREME NOOB...
Yes use the caps you have.
For the 6pin mod for start just measure the coils to see which get 12v...for start because after that it becomes really tricky...
Old 02-11-2010
Kriztoffer's Avatar
OC Alliance
I will look into it over the weekend. Is there any signaficant gain from the extra 6pin mo?
I was looking after some heatsinks for my 5870 to use under ln2.
Anyone have any experiance with this kit from scythe?
http://www.scythe-eu.com/en/products...heatsinks.html
slipping the clutch
Old 02-11-2010
Umm.. you are recapping and vmodding your board...
Shouldnt you be looking for a new GPU pot? lol
