Overclockaholics Forums » Hardware Section » Cases » DimasTech BenchTables V2.5
Old 02-10-2010
Dimas Dimas is offline
Dimastech
Dimas is just getting started
Default DimasTech BenchTables V2.5
Hello Guys, i'm Andrea, alias Dimas on forums, i was mostly a phase change builded in the past, but i decide to make also benchtables time ago, i did some experiments, some research, and what i'm about to show it's the last project we finish...
we have also some other good product related to overclockers incoming, like watercooling parts and new Phase Change coolers, but here we will show our New Test Station, i'd like to thank Kal for inviting me here, for sharing the develop, the process and if possible for you guys to suggest new ideas, are always welcome...
let's go on...
Here Below the Final Revision of Table Easy V2.5, this is the Standard Version, no customization, all the accessory like USB cable, FlexFan or other things are adding parts
Bench Table Easy V2.5 Specifications
-Single Model available, this model will cover all the old V2 versions
-Tipical U bend shape, 90 degrees round corner
-down tray now have a sledge and the fasteners are thumbscrews
-positioning of the support for optical and Hd on Slot, not just on holes
-lateral customization with the name of the product "DimasTech V2.5"
-Compatibility with all the radiators on market(hwlabs, thermochill, tfc, ecc...ecc...)
-no more bolts and hand tools to use, also the bolts are thumbscrews now
-no more hand tools on all the benchtable
-4 hard disk support, 3,5"
-3 optical drive , 5,25"
-new slot for cable passing
-custom cut on the back saying "MADE IN ITALY"
-motherboards Mini ATX compatibilty / motherboards XL-ATX / E-ATX and Micro-ATX
-rubber feet M4 thread for Hand screwing
-3 standard colors always available without painting waiting (black glossy, metal grey and milk white)
-custom color on booking
-full compatibility with new Bench Table Hard V2.5
-4 back holes for water cooling tube passing or for waterccoling fittings
-new Power On and Reset Button "P" and "R" with red and black shrink cables
-USB front Port for Single Pen Drive, very usefull for saving screenshots and no boring about find the Rear USB ports (USB Cable is an Accessory)
-Male - Female spacers, no more need of screw for the motherboard Spacers
-FlexFan supports available as accessory, chromium and black powder coating, it fits on all of the Bench tables done from the begin (v1.4) to the last V2.5 (more news on this accessories in next week)
-XL-ATX vga support available as accessory (10 slots)
Hardware Assembled Air Cooling, Only USB CABLE accessory
Soon to be available PDF mounting GUIDE
Bench Table Hard V2.5 Specifications
-Single Model available, this model will cover all the old V2 versions and perfect matching the new Bench Table Easy V2.5 ( bench Table Easy + Bench Table Hard = EasyHard bench Table)
-full compatibility with new Bench Table Easy V2.5
-redesigned Arch-Press to be more easy to fix and easy to screw pots or other cooling device to CPU
-Bachelite Handles
Hardware Assembled Air Cooling, No Accessory
PDF mounting guide for that table too
From the Fusion of Bench Table Easy and Bench Table Hard, born EasyHard, this 2 bench tables can be used together or separate, it perfectly match through rubber feet and special screw on the top of Bench Table Easy, with that setup the Hard Bench Table can't move in any direction, like the older bench table.
Bench Table EasyHard V2.5 Specifications
hard part
-Bachelite Handles
easy part
Hardware Assembled Air Cooling, No Accessory, only Usb Cable for Easy Part
Old 02-10-2010
Dimastech
Developing Pics, preseries and parts not assembled, packaging sample and FlexFan first try
Bench Table Easy V2.5 Develop Pics
Old 02-10-2010
Dimastech
Old 02-10-2010
Gunslinger's Avatar
Overclockaholic
Don't forget to post some pics of the "hard" version also.
Old 02-10-2010
Man I love your designs! Wish you had one just a little smaller. I'm interested in one just slightly bigger than the Classified mobo itself and have the lower compartment for a PSU, hardrive or two and CD. Not interested in all the water cooling stuff, just DICE/LN2 benching. The hardtable rocks though and will prolly suite my needs for the time being.
Old 02-10-2010
Dimastech
yes Mate, it's a pita to make pics to all different colors but will be done until end of week
Old 02-10-2010
You have a link to where these can be bought at for those that don't know?
Old 02-10-2010
Dimastech
assassin post some news in this thread there's also the link where to see, dont' look at picture, have still to be updated...
http://overclockaholics.com/forums/s...ead.php?t=1795
about the table you asked, i think it can be arranged, just sum up all of your request, and i'll see if is a project we can develop
Old 02-10-2010
Thank you for posting Dimas, you have a fine product line at Dimastech and we're happy to have you here at OCA.
Old 02-10-2010
My request is simple. I need room for a mobo, PSU and a set of harddrives. I have a portable CD drive so having room for one on a bench table is pointless or at least for me. The table needs to be slimmed lined as possible. I transport my setup all the time, mainly to whatever part of the house is coolest, sometimes the garage so it needs to be light. I use the Classy as reference as that is what I bench with. Needs to be a little bigger than that. Here is a picture of my current bench table setup with old hardware on it. I love it but hate it as it is plastic. I custom made a bracket to house a set of 120mm fans to blow across the RAM, vreg as well as NB.
I currently have a set of 120mm x 38mm fans on there now instead of the 25mm. Your current table would work minus all the water cooling space. That would prolly get the job done. Hopefully this helps or maybe even gives you new ideas.
