Old 01-15-2010
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
Default Laptop Overclocking
Is it possible being that most bioses have so few settings to play with? And is it even worth it for boints on the bot??
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 01-15-2010
What you are prolly talking about is a locked BIOS or whatever you want to call it that doesn't allow for overclocking there for not having the features you are accompanied to in your normal run of the mill BIOS you overclock in everyday. For instance a HP or Dell BIOS. At least that is what I think.
Old 01-15-2010
Jeffro64's Avatar
Yes Sir... A Dell to be exact.
Main Rig
Old 01-15-2010
You would have to use an in operating system tool like setfsb or the like. It's kinda hard to keep settings on cpu's though, since there is no way to disable speedstep and cool & quiet on most lappy's.
I ran evga precision on a couple laptop gpu's... didn't get much out of them. it may be possible to tweak with eleet, but I haven't tried..... bet it's fun though!
Old 01-15-2010
IF you really want to push a laptop, yes you will have to use software to do it.
I would recommend if doing so and you are comfortable with it. completely dismantling the laptop though set it up on a desk and put some better cooling on the CPU and/or GPU so you can really take out the competition
Old 01-15-2010
Jeffro64's Avatar
Gotcha... that was a thought but wasn't sure how it would work.
Yeah, I might look into the software to do it.... Dismantle for better cooling for sure!
I was just thinking.... I have all this older HW and a couple of laptops lying around and thought it might be fun and good learning trying to do something with them. And maybe pick up a few bonus points while i'm at it. The day is finally drawing near yhat I should have some time to get back to thrashing hardware... And i'm trying to get really pumped and excited about it again.
Main Rig
Old 01-15-2010
I had fun clocking my laptops and finding out which one was actually faster than the others in as many benchmarks as it would run.
Old 01-15-2010
Jeffro64's Avatar
Was it good for any points on the bot?
Main Rig
Old 01-15-2010
At the time, yes. If its a common notebook, theres a good chance you'll get more than the vanila .01 points. Either way, its rather interesting to see the 2d results compared to existing results at the bot.
I had to do what I could to get the benches to run as fast as possible since all my laptops were dell's.
Old 01-15-2010
Jeffro64's Avatar
That's where i'm at.... Dell's.
Main Rig
