Old 03-18-2009
skarface's Avatar
skarface skarface is offline
skarface is just getting started
Default classified mobo
Did everyone take a glance at the new mobo by evga? Its pretty interesting they have ginormous nb heat sink on it. The price is very high tho evga has it priced at 459.99. If the wife doesnt kill me i might try to switch to i7 and the works! I just hope the 1 grand and some to switch will be worth it.
Old 03-18-2009
Honeslty bro you'd be better off with the regular evga X58 or your choice of another brand. With you running 295's it has been stated that you will take a performance hit in games because of the increased latency with the nf200 chip.
Old 03-18-2009
I dunno bout the performance hit there chuckos, seems like you'll actually get 1fps better than non-nforce chip mobos.
Far as the standard x58, well, that mobo had a host of problems and you can tell from the step up cue that x58 standard owners wernt too happy. I'd wait and see what kinda numbers and complaints churn outa the x58 classified before plopping down the big dough. If things look great and you can afford it, then launch away
Old 03-18-2009
skarface's Avatar
So go with the standard x58? I like evga but i really like that x58 extreme gigabyte board. Know whats funny i just spent like 100 bucks for more water cooling stuff on my 780i ftw board. Damn technology they should slow down some i dont have the bank account to rebuild every 6 months!
Old 03-18-2009
Honestly supes, I haven't even looked at a review of the board yet. I'm kinda going off how the P6T6 Revolution did and what Andre Yang and even Shamino stated themselves. I do remember seeing Andre and Sham say that you will get a small hit if running Quad SLI/XFIRE. For Tri SLI/XFIRE it's supposed to give the advantage. :confused:
Old 03-18-2009
skarface's Avatar
More advantge with 3 gpus vs 4? So are the vids passing up the technology to back them????
Old 03-18-2009
Quad SLI has been a flop since the first iteration of quad sli back in the 7 series gpu's I think it was. Its a driver problem that they've never really solved.
Gotta remember how sli works, SLI splits the on screen dutys in half while tri-sli splits it up three times and quad sli well, four times. Thats alot of paralell syncronized processing going on. I'm not an expert but I'd reckon this is where the driver struggles in its dutys.
Honestly, the performance advantages between sli and trisli vary from gen to gen. It all depends on if you're overclocking and how much. For gaming, it depends heavily on the game playin nice with the drivers as well.
Old 03-18-2009
skarface's Avatar
Makes me wonder if they should be work on a firmware update vs newer cards and drivers!
Old 03-18-2009
Thumbs down
Well, then they would stop making money altogether as the 8800ultras would still be the top performers of the day
Nah, they gonna stick it to us every 3-6 months like usual and play catch up with the drivers as they prepare for the next launch.
Old 03-18-2009
skarface's Avatar
Yea im begining to wonder if i made a big mistake switching from the tri 280s to the 295s. So far only difference is ive lost some frames in some games and picked up in others. But now i cant play crysis at all! freakin crysis
