Old 12-04-2009
karmakazi's Avatar
Talking Incoming....!
Figure I would share my new build here also
Yes, yes, the LN2 freak is getting a cascade
Old 12-04-2009
karmakazi's Avatar
Then the next day I got this in my inbox...
Followed by this message the next night...
ok sounds good to me I will put gauges on the second stage I don't think that they are needed for the first stage as well as I do have the first stage done and it will be running today I hope then tomorrow I will go out and buy the gauges and the cap tubes I need to get the second stage all running as I need 2 captube one 0.031 and one 0.036 some poe for another system I am building as well thinking of changing the cap tube on that system as well so I guess I need 2 0.036 cap tube and get the gauges. now for your hotgas bypass I will just be using as hand valve and I big cap tube so u can ajust the temp u would need to get past the coldbug so I guess for me having it done for the 28th I should have it done by then hoping to have it together this week then that gives me like 3 weeks to test and tune the system as well I just have to make new mounting bracket for the evap as this mounting does not have 1366 on it. can u think of anything else u would like if u do feel free to ask and I would do my best to help out
Old 12-04-2009
karmakazi's Avatar
And then today I received this !!!!
Old 12-04-2009
karmakazi's Avatar
I already got the perfect place to put it too. 4 foot tall, 3 level steel cart on beefy wheels. Cascade will go on the middle shelf, benchtable on the top. Lowest level can hold random stuff like shop towel, torch refills, insulation, etc.
Im psyched :p
Old 12-04-2009
Very cool stuff ... can't exspand pics???
subscribed
Me and a team mate are working on a in house design for an SS
not quite ready for two stage prime time yet ....
Old 12-04-2009
karmakazi's Avatar
Yeah pics were received that small unfortunately.
I should have it on Dec 28th, when Jody (3oh6) comes down to my place for a bench sesh. Hope to have some 5970 lovin by then to bench. Of course a gulftown might be present also....
Old 12-04-2009
howd you swing a gulftown?
that sounds like a lot of fun...
you should post up some pis and numbers of all that
two stager looks nice man ....
Old 12-04-2009
Nice.... Keep us posted. I still would like to get a phaser one day. If I were to dream it would be cascading.
Old 12-04-2009
Very nice
Old 12-05-2009
Ruffus is a great guy, I bet he wont even have taken the full amount from you yet.......
