Overclocking Air & Water...
Old 11-19-2009
Default My runs 920 w/UD5
Still trying to figure out this i7 setup, so ill post more runs with different benchmarks
Setup:
I7 902 D0 A batch on a small 120 rad
UD5
3gb PI Blacks
5770
750tx Corsair PSU
my runs so far
4.66ghz @ 1.5v in bios but 1.47 in CPU-Z with LLC enabled
a little better
and this one so far for some hwbot points
3DMark 03
will continue some more runs, i have a dice pot but it wont work with i7 at holding temps.
Old 11-19-2009
Nice 920 you have there.
Old 11-19-2009
Wow. 223 out of the box eh... im jealous
Old 11-19-2009
What sticks yah running?
Old 11-19-2009
Is that the new version ???? I think 1.6
my EX-58 hit the wall at 222 .........
Nice prime runs ......
Old 11-19-2009
theres a pcie SMD mod that will net you over 230 if you need it
Old 11-19-2009
Thanks for the tip bro...
but I got rid of it already....
3x SLI EvGA on the way .... couldn't afford the Classy ..........
But the last owner said 235 to 240 is doable on it so i am hoping for the latter ....
Hoping to be up and running by months end......
Old 11-19-2009
I kind of cheated on the BCLK, i booted @ 222 and just bumped it to 223 with SetFSB so i could run 4.7
how can i tell what sticks i have ?
I'm slowly learning how to overclock ram so its not the best.
Old 11-19-2009
WOW If you figure out how let me know. I am stuck at 222. 223 is insta-freeze.
It should say right on the side of the sticks You can google the model to find out the ICs on them, if you are scared to remove the heatspreaders. I bought cheap ram, took the heatspreader off found the IC on them and from there was able to google and find out what types of latencies and voltages it needs to blow past 2000 MHZ
Old 11-19-2009
Upping the PCI-E always helps for 222 i need PCIE @ 102
this is the only info i could find but its 6gb instead of 3gb
http://www.xtremesystems.org/forums/...d.php?t=212624
